Ik kan mijn autorisaties niet verwijderen van de computer; computer zegt steeds probeer het later opnieuw, maar ik probeer het al dagen; ik kan ADE ook niet koppelen aan mijn e-reader op deze manier, het lijkt of de autorisaties niet goed zijn, heb al nieuw password, maar krijg de autorisatie er niet af
Do you used Windows or Macintosh?
I use Mac. Password is correct.
Hi, thanks for your answer. I think really that this is the solving of the problem. But I have no experience in searching for hidden files. I tried many options, but I can't find it. I use u MacBookPro, operating sytem El Capitan. Can you show me the steps to follow? Thanks in advantance
Have you try the steps under this Link: Access hidden user library files | Mac OS 10.7 and later?
yes, I tried, but I still can't find the hidden library files. Sorry. Maybe it is better to contact a computer-shop for helping me with this. For so far, thanks for your answer, I really think the solution is delete the activation.dat file, but I can't do that myself.
When you write with which point you has a problem i can try to help. On which step of Access hidden user library files | Mac OS 10.7 and later do you not found the right point.
the first step .... In the finder, choose Go ..... Go to the Folder
Can you take over my computer? I've heard Adobe can take over someone's computer .... I also started a chat, but it's busy
When you have start the Finder you have on top of the screen a meno. Its start with Finder, File and so one. One of the Point is Go and under this you found go to the folder. 😄
O there! sorry,but I've found it. But now the following steps? To which folder have I to go?
I found the file!! Thanks!!!!!
Sorry I didn't understand how to find Go in Finder, but I looked on the wrong place. But I've found the file and I have deleted it. Thanks a lot for your patience and your help!
I have now authorized ADE again and that was succesfully. The first book is now downloaded and I can read it. I'm very happy!
Your are Welcome.
Werkte perfect. Dank!
ik ben er ook al dagen mee bezig. ze willen gewoon niet dat je het verwijderd
Iemand hier ervaring mee met Windows?
