Hi again Robonetx5
Whether you like it or not, your end solution will likely
involve simply re-creating the database information for your
RoboHelp projects. I say this because it's likely going to be
infinitely easier than tracking down what went wrong and making a
change here and there. Of course, if we were able to sit in front
of the affected PC and really see the structure, we could probably
sort it. But as you are stepping into a project with many unknowns,
it's probably going to be a daunting process at best.
Normally, you want to configure your "working folder" in VSS
to match exactly your project location. As you add folders in
RoboHelp HTML, you will want to be sure you also add them in VSS.
Same with new topics and images.
I wish you the best of luck in getting it resolved easily.
Cheers... Rick
