2 Replies Latest reply on Nov 14, 2015 8:09 AM by Ruyooka
    Unable to add music from iTunes to slideshow.
    Ruyooka
      In iTunes (latest version), I do not have the Create AAC version option. What am I doing wrong?
        • 1. Re: Unable to add music from iTunes to slideshow.
          Mohit Goyal Adobe Employee (Admin)
          Hi Ruyooka,
          Please follow the below instructions.
          In Preferences (CTRL + ,), in the General tab, click on Import Settings.
          You need to select AAC Encoder in the Import Using drop down menu.
          Now Create AAC Version should appear in your right-click context menu.
          related link: iTunes 12 has no option to create AAC version | Apple Support Communities
          If the above steps don't work, please contact the manufacture.
          Let us know if that helps.
          Regards,
          ~Mohit
          • 2. Re: Unable to add music from iTunes to slideshow.
            Ruyooka Level 1
            Thank you Mohit. Very helpful. I am now able to create AAC versions of the music. However, I am still unable to add the music. I do as follows:
            Click on  + Add Music
            Takes me to iTunes
            I select the music (AAC version)   (Blue Monk by Theloneous Monk)
            Add Music Results Box pops up, with the following message:
            Some music files could not be added
            The music file is not well formed. (1)
               1-01  Blue Monk 1.m4a
            Tried different songs, different genres. Same result.
            Now, I tried again and I get the same error message above but this time it says: 1-01 Blue Monk 3.mp3, suggesting the problem is not with iTunes.
            I called Apple support. The kind gentleman did a screen share with me and there appeared to be no problem with iTunes. Seems my copies of LR and iTunes "not talking."
            Ruyooka
