3 Replies Latest reply on Nov 16, 2006 5:32 PM by mirianam
    Play sound fx once a second
    mirianam
      I have a countdown timer that countdowns from 25 seconds.
      I would like to add a "tic" sound fx which plays once every second but can't get my head around how to do this
      Here is the code I am using for the countdown.
      Can anyone guide me on this please.
      global gScore
      -- behaviour script attched to a text sprite
      on beginSprite me
      gScore = 0
      sprite(me.spriteNum).member.text = "0:25"
      startTimer()
      end beginSprite
      on enterFrame me
      tSecElapsed = (the timer)/60
      if tSecElapsed < 25 then
      tTime = 25 - tSecElapsed
      tSec = tTime mod 60
      if tSec < 10 then
      tSec = "0" & tSec
      end if
      tMin = tTime/60
      sprite(me.spriteNum).member.text = tMin & ":" & tSec
      else
      sprite(me.spriteNum).member.text = "0:00"
      end if
      if gScore = 55 then pass
      else
      if sprite(me.spriteNum).member.text = "0:00" then
      go to "drown"
      sound(4).play(member("LiquidDrops"))
      end if
      end if
      end enterFrame
        • 1. Re: Play sound fx once a second
          Level 7
          See additions to your code below
          "mirianam" <webforumsuser@macromedia.com> wrote in message
          news:ejh2d3$ora$1@forums.macromedia.com...
          > can't
          > global gScore
          property pCurrentSec
          > on beginSprite me
          > gScore = 0
          pCurrentSec = 25
          > startTimer()
          > end beginSprite
          > on enterFrame me
          if tTime < pCurrentSec then
          pCurrentSec = tTime
          -- play your sound here
          end if
          > tSec = tTime mod 60
          > if tSec < 10 then
          > tSec = "0" & tSec
          > end if
          > tMin = tTime/60
          > else
          > end if
          > else
          > go to "drown"
          > end if
          > end if
          > end enterFrame
          • 2. Re: Play sound fx once a second
            duckets Level 1
            You'll need to add a property to your behaviour which remembers the 'seconds' value from the previous frame, and only play a sound if the current 'seconds' differs from what it was the previous frame. I've attached a modified version below. The extra code is added after the line where you assign 'tSec'. I've also added a property to store the sprite reference which neatens the code (sorry, I'm a bit obsessive with that sort of thing!)
            • 3. Re: Play sound fx once a second
              mirianam Level 1
              Thank you very much for your help
              I tried so many different things but I was heading in a completely wrong direction.
