10 Replies Latest reply on Jun 18, 2008 12:18 PM by yupieyi
    Off-canvas items are invisible
    Max Stewart Level 1
      In Flash, work-in-progress items parked temporarily in the area surrounding the stage remain visible. In my FW (V8), they are invisible except for their boundary box (and even then only when when selected).
      I feel sure there has to be an option in FW to make off-canvas items always visible but cannot find it. What pls am I doing wrong?
        • 1. Re: Off-canvas items are invisible
          Level 7
          There is no such option in Fireworks. I'd like to see one myself.
          Linda Rathgeber [PVII] **Adobe Community Expert-Fireworks**
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
          • 2. Re: Off-canvas items are invisible
            lukearndt1
            After a bit of searching, I came across this thread. Like the OP, I would love to be able to make those out-of-canvas items visible. It's a real pain to only be able to view what's inside of the canvas. Why can't things be placed "off-stage"?
            If anybody has any sort of workaround, I would love to hear it! I like Fireworks, but I'm having trouble with this limitation. I'm so used to being able to throw something off-stage for a bit, but with FW it's really hard to adjust.
            -Luke
            • 3. Re: Off-canvas items are invisible
              pixlor Level 4
              Well...it's definitely a workaround, but...
              Make your image nice and large. As the first layer, put a rectangle that is the size you want your final image to be. Don't put anything else on that layer. Lock the layer while you work.
              When you get ready to export, save a copy and do the final output from that. As the first step, turn off visibility of all layers except the first one with your background rectangle. Unlock it. Select the rectangle. Go to Modify>Canvas>Trim canvas. Now, you have an image that is the size you want. Bitmaps that are not wholly within the rectangle are cropped. Objects that are completely outside the rectangle are deleted. (This is why you want to work with a copy.)
              If you want a transparent background, turn off the visibility on the background rectangle or delete it.
              • 4. Re: Off-canvas items are invisible
                Level 7
                Hi Luke,
                > being
                > to
                > adjust.
                One way of dealing with that is make the canvas as large as you need for the
                whole work area, put the stuff you're not using on the side or bottom, then
                just draw slices around the stuff you want to export, and export just those
                slices - that's what I do.
                Aloha,
                Jerry
                • 5. Re: Off-canvas items are invisible
                  Jonbon999
                  yep exactly the correct info there
                  • 6. Re: Off-canvas items are invisible
                    lukearndt1 Level 1
                    Thanks for the ideas, Lorraine and Jerry.
                    I like your solution, Jerry. That seems to be a fairly painless workaround. I still am confused as to why Fireworks behaves this way in the first place, but this is a big improvement.
                    • 7. Re: Off-canvas items are invisible
                      RolyRoger
                      I feel fireworks still has room for improvement
                      • 8. Re: Off-canvas items are invisible
                        JoeDaSilva Level 4
                        Dude can you knock it off with your stupid sock-puppet accounts and constant spam?
                        quote:
                        • 9. Re: Off-canvas items are invisible
                          thanks for the information.i think that this option can replace with other facilities available in the fireworks.
                          • 10. Re: Off-canvas items are invisible
                            yupieyi Level 1
                            That's one really cool blog. Joey!
