0 Replies Latest reply on Nov 14, 2015 8:43 AM by mariappand99913066
    How to Save Uploaded image to the server from Flash As3
    mariappand99913066 Level 1
      Hi everyone!!
      While browsing & uploading images from local drive I need to save the uploaded image in a folder at server (PHP)
      It has to be done automatically once the uploading is finished.
      Here is the code:
      import flash.events.MouseEvent;
      import flash.net.FileReference;
      import flash.net.FileFilter;
      import flash.utils.ByteArray;
      import flash.events.Event;
      import flash.events.IOErrorEvent;
      import flash.display.MovieClip;
      import fl.controls.ProgressBarMode;
      var mFileReference:FileReference;
      // Setup button to handle browsing
      browseButton.buttonMode=true;
      browseButton.mouseChildren=false;
      browseButton.addEventListener(MouseEvent.CLICK, onBrowseButtonClicked);
      // Hide progress bar
      progressBar.visible=false;
      // This function is called when the BROWSE button is clicked.
      function onBrowseButtonClicked(event:MouseEvent):void
        trace("onBrowse");
        mFileReference=new FileReference();
        mFileReference.addEventListener(Event.SELECT, onFileSelected);
        var swfTypeFilter:FileFilter = new FileFilter("SWF/JPG/PNG Files","*.jpeg; *.jpg;*.gif;*.png");
        var allTypeFilter:FileFilter = new FileFilter("All Files (*.*)","*.*");
        mFileReference.browse([swfTypeFilter, allTypeFilter]);
      // This function is called after user selected a file in the file browser dialog.
      function onFileSelected(event:Event):void
        trace("onFileSelected");
        // This callback will be called when the file is uploaded and ready to use
        mFileReference.addEventListener(Event.COMPLETE, onFileLoaded);
        // This callback will be called if there's error during uploading
        mFileReference.addEventListener(IOErrorEvent.IO_ERROR, onFileLoadError);
        // Optional callback to track progress of uploading
        mFileReference.addEventListener(ProgressEvent.PROGRESS, onProgress);
        // Tells the FileReference to load the file
        mFileReference.load();
        // Show progress bar
        progressBar.visible=true;
        progressBar.mode=ProgressBarMode.MANUAL;
        progressBar.minimum=0;
        progressBar.maximum=100;
        browseButton.visible=false;
      // This function is called to notify us of the uploading progress
      function onProgress(event:ProgressEvent):void
        var percentLoaded:Number=event.bytesLoaded/event.bytesTotal*100;
        trace("loaded: "+percentLoaded+"%");
        progressBar.setProgress(percentLoaded, 100);
      // This function is called after the file has been uploaded.
      function onFileLoaded(event:Event):void
        var fileReference:FileReference=event.target as FileReference;
        // These steps below are to pass the data as DisplayObject
        // These steps below are specific to this example.
        var data:ByteArray=fileReference["data"];
        trace("File loaded");
        mFileReference.removeEventListener(Event.COMPLETE, onFileLoaded);
        mFileReference.removeEventListener(IOErrorEvent.IO_ERROR, onFileLoadError);
        mFileReference.removeEventListener(ProgressEvent.PROGRESS, onProgress);
        browseButton.visible=true;
        var movieClipLoader:Loader=new Loader();
        movieClipLoader.loadBytes(data);
        movieClipLoader.contentLoaderInfo.addEventListener(Event.COMPLETE, onMovieClipLoaderComplete);
      function onFileLoadError(event:Event):void
        trace("File load error");
      // This function below is specific to this example.
      // It does the processing required to display the swf/png/jpeg file that we have just loaded.
      function onMovieClipLoaderComplete(event:Event):void
        var loadedContent:DisplayObject=event.target.content;
        var loader:Loader=event.target.loader as Loader;
        // Fit to stage
        trace("loadedContent.width="+loadedContent.width);
        loadedContent.scaleX=container.width/loadedContent.width;
        loadedContent.scaleY=container.height/loadedContent.height;
        trace("loadedContent.scaleX="+loadedContent.scaleX);
        trace("this.stage.width="+this.stage.width);
        container.addChild(loader);
