1 Reply Latest reply on Nov 16, 2015 5:32 AM by Loic.Aigon
    XML code ends up in 1 text box rather than separate text boxes
    urbanl28974291
      I'm trying to put some XML-based tables into separate text boxes, i.e., one table per page.
      My code (simplified version is below) works except that it puts all 3 tables into the text box on page 3 rather than table 1 into the text box on page 1, table 2 into the text box on page 2, and table 3 into the text box on page 3.
      I have to assume that there is just one little thing I'm missing, but after struggling for a couple of days revising my code multiple times, I thought it was time to ask for help.
      Any hint as to what needs to be changed?
      Thanks!
      main
      Function main()
        Set myInDesign = CreateObject("InDesign.Application")
        mySetup myInDesign
        i=0
        Do Until i>2
          i = i + 1
          myXMLFilePathName = "c:\XMLTable" & i & ".xml"
        myImportXML myInDesign, i, myXMLFilePathName
        Loop
      End Function
      Function mySetup(myInDesign)
          myInDesign.ActiveDocument
      End Function
      Function mySetupDoc(myInDesign)
        Set myDocument = myInDesign.Documents.Item(1)
        With myDocument.DocumentPreferences
        .PageHeight = "800pt"
        .PageWidth = "600pt"
        .PageOrientation = idPageOrientation.idPortrait
        .PagesPerDocument = 3
        End With
      End Function
      Function myImportXML(myInDesign, i, myXMLFilePathName)
        Set myPage = myDocument.Pages.Item(i)
        myDocument.ImportXML myXMLFilePathName
        Set myRootXMLElement = myDocument.XMLElements.Item(1)
          set myTextFrame = myDocument.Pages.Item(i).TextFrames.Add()
          myTextFrame.GeometricBounds = Array ("0.5i", "0.5i", "10.5i", "8i")
        myRootXMLElement.PlaceXML myTextFrame
      End Function
        • 1. Re: XML code ends up in 1 text box rather than separate text boxes
          Loic.Aigon Adobe Community Professional
          It's likely an issue with a reference but I wouldn't say for VB. Here is some attempt in JS:
          var main = function(){
            var count = 3, tf;
            var fo = Folder.desktop;
            var xf, root, tag, xe;
            var doc = app.documents.add();
            doc.documentPreferences.pagesPerDocument = count;
            root = doc.xmlElements[0];
            tag = doc.xmlTags.item("tf");
            !tag.isValid && tag = doc.xmlTags.add("tf");
            while ( count-- ) {
            xf = File ( fo+"/table"+(count+1)+".xml" );
            if ( xf.exists ) {
            tf = doc.pages[count].textFrames.add();
            xe = root.xmlElements.add(tag);
            xe.importXML ( xf );
            tf.placeXML ( xe );
          main();
          Loic
          www.ozalto.com
