I'm creating some bitmaps that are larger than 8,191 pixels. Everything works fine on iOS... even 20,000 pixels and above.. on Android anything over 8,191 hangs my app.
Does anyone have experience with this or know of a workaround? Had to completely remove a feature from my Android app because of this.
According to the Adobe ActionScript 3 documentation (linked below and possibly not up to date since it references AIR 1.5 specifically), a DisplayObject cannot have more than 16,777,215 pixels ( 4096*4096 - 1, 2048*8192 - 1, 1024*16382 - 1) contained within it. Depending on how wide your images are, over 20000 pixels tall (838px wide in that instance) seems like it is possible according to the docs. But the version of OpenGL Android uses is different per Android OS version, and the capabilities change based on the version. So you may need to look into what the limitations are of the Android device and OS you are testing with to know what you can do. It could be a memory issue or it could be an image size limit of the Android device you are testing with.
Question. Why are you needing to create images that big in size? If you really do, you could split them up into multiple images and have the X/Y positions place the second image directly after the first.
DisplayObject - Adobe ActionScript® 3 (AS3 ) API Reference
http://developer.android.com/guide/topics/graphics/opengl.html
The reason I need to capture an image that large is because its an image of a massive visual checklist... bitmapdata gets passed to a social ANE to share on Facebook, iMessage, etc.
Normally in these situations you would create several smaller bitmaps and tile them (but them inside a Sprite, for example).
If flash still won't let you do this because the total width/height exceeds the limit, then you'll need to add/remove them from the display list as the user scroll to view it.
However - it's not going to help though if you need to pass that BitmapData around (to the ANE you mention). Can you scale it down (BitmapData.draw) to a smaller bitmap before passing it to the ANE, or does it need to be that big?
Dumb question ...
If the sprite that I'm capturing is say 600px x 21,000px .. how do I capture it smaller than it actually is ? Wouldnt I still have to capture the large bitmap and then resize it ?
BitmapData.draw() and BitmapData.drawWithQuality() can both take a matrix parameter. You use that to scale down the contents that are grabbed.
Yes, Colin is correct. You use matrix.scale
I've never used matrix.scale ... would that be easy to adapt to this ?
if(currentOS == "Android"){
shareHeight = 9420;
rectangle = null;
rectangle = new Shape; // initializing the variable named rectangle
rectangle.graphics.beginFill(0xFFFFFF); // choosing the colour for the fill, here it is white
rectangle.graphics.drawRect(0, 0, 640,shareHeight); // (x spacing, y spacing, width, height)
rectangle.graphics.endFill(); // not always needed but I like to put it in to end the fill
myBitmapData = null;
myBitmapData = new BitmapData(640, shareHeight);
myBitmapData.draw(rectangle); // Add white rectangle
myBitmapData.draw(charactersMain_mc, new Matrix(1, 0, 0, 1, 5, 10)); // Add Movieclip
Any help is appreciated..
The short answer: yes
I haven't tested this, but try something like:
shareHeight = 9420;
shareWidth = 640;
maxBitmapSize = 1024; // or whatever you want maximum to be
var scale : Number = Math.min( maxBitmapSize / shareHeight, maxBitmapSize / shareWidth);
var scaledWidth : int = int( shareHeight * scale );
var scaledHeight : int = int( shareWidth * scale );
rectangle = null;
rectangle.graphics.drawRect(0, 0, scaledWidth , scaledHeight); // (x spacing, y spacing, width, height)
var matrix : Matrix = new Matrix();
matrix.scale( scale, scale ); // I think this is the correct order, but might need to swap scale and translate
matrix.translate(5, 10);
myBitmapData = new BitmapData( scaledWidth, scaledHeight );
myBitmapData.draw(charactersMain_mc, matrix); // Add Movieclip
By the way, you could completely skip the whole drawing of the rectangle in the above example, and replace it with a fill color passed in to the BitmapData constructor:
shareHeight = 9420;
shareWidth = 640;
myBitmapData = new BitmapData( scaledWidth, scaledHeight, false, 0xFFFFFF ); // Initially fill with solid white
But I'm guessing this is a simplification of your code, and there is actually other content in the rectangle?
