32 Replies Latest reply on Jan 9, 2016 3:52 PM by daveujn
    Help Please! Required codec is not installed
    daveujn
      Hi
      I wanted to import some movie files from my iMac to start a new project and received this error message
      " This type of file is not supported, or the required codec is not installed"
      but if I just continued the files were added to the project, which has happened before, with no obvious problem.
      The problem this time is that I can add the clip to the timeline and play it back ok but if I want to add a transition and then render, when it is finished the audio can be heard but not the video.
      Any advice would be appreciated
      I use an iMac and premier elements 10
      Dave
        • 1. Re: Help Please! Required codec is not installed
          Open one of your video files in the free download Media Info and post the resolution, frame rate and audio and video codec it displays.
          Note that, in Premiere Elements 10, you must manually set up your project to match your video specs -- something you can't do until you know what the video specs are.
          • 2. Re: Help Please! Required codec is not installed
            A.T. Romano Level 7
            Dave
            Already asked are the must know video audio properties of the file that you are trying to import into your Premiere Elements 10 Mac project.
            But, also....
            What video card/graphics card does your computer use.
            There is a serious known issue with Premiere Elements 10 on a computer that uses a NVIDIA GeForce video card/graphics card.
            http://atr935.blogspot.com/2014/02/pe10-nvidia-video-card-roll-back.html
            Good to rule in or out at the onset whether or not any of that applies to your situation. The solution for this is to roll back the driver version to May 1013 if the older driver still exists.
            Do you have the latest version of QuickTime 7 installed on your computer with Premiere Elements 10? And, are you running the programs as administrator (from a user account with administrative privileges)? What players do you have installed on your computer?
            ATR
            • 3. Re: Help Please! Required codec is not installed
              daveujn Level 1
              Steve
              Where do I find the free download media info?
              Dave
              • 4. Re: Help Please! Required codec is not installed
                daveujn Level 1
                ATR
                The graphics card is an AMD Radeon HD 6750M 512 MB
                Quicktime player is version 10.4
                I am running as administrator
                Players installed is just quicktime.
                • 5. Re: Help Please! Required codec is not installed
                  A.T. Romano Level 7
                  daveujn
                  Great news that your computer is not using a NVIDIA GeForce video card/graphics card when you have Premiere Elements 10 installed on the computer.
                  The MediaInfo Mac video audio properties readout program can be found
                  http://mediainfo-mac.en.softonic.com/mac
                  Just be careful with your decisions in downloading and installing MediaInfo programs since they are known to travel with unwanted baggage.
                  Look for the Tree View in MediaInfo to explore its video and audio properties.
                  Sometimes I can get all the troubleshooting information that I need from the brand/model/settings of the camera that recorded the video.
                  Basic information includes
                  Video compression
                  Audio compression
                  Frame Size
                  Frame Rate
                  Interlaced or Progressive
                  File Extension
                  Pixel Aspect Ratio
                  Problems ranging from audio out of sync or not being able to import the file can come from video audio recorded with a variable, instead of a constant, frame rate...characteristic of cell phone, iPad.
                  Another free tool for getting at properties of the file is the codec utility named GSpot.
                  GSpot Codec Information Appliance
                  its Video Name Codec Status and Audio Codec Status information can be very helpful.
                  Same goal for all of the above....getting at the video audio properties that might be in conflict with the project settings and workflow.
                  Please consider. We will be watching for your reply as your schedule permits.
                  Thank you.
                  ATR
                  • 6. Re: Help Please! Required codec is not installed
                    daveujn Level 1
                    Hi ATR
                    The model of the camera is a Sony HDR-CX130E
                    When I get the error code above the clips to be imported it determines the clips as Cache.plist
                    Have also located this information from one of the clips.
                    File: /Volumes/Videos/Georgia 2014  outside/clip-2013-06-30 00;21;13.mov
                    Format: QuickTime/MPEG-4/Motion JPEG 2000 format
                    Stream count: 3
                    Duration: 00:00:06
                    Bit rate: 121705 kb/s
                    Meta info:
                        compatible_brands: qt
                        minor_version: 537199360
                        creation_time: 2014-08-25 12:07:49
                        major_brand: qt
                    Stream 0
                    Type: video
                    Codec: Unknown codec
                    FourCC: icod
                    Duration: 00:00:06
                    Width: 1920
                    Height: 1080
                    Sample aspect ratio: 1:1
                    Display aspect ratio: 16:9
                    Frame rate: 25 fps
                    Bit rate: 120075 kb/s
                    Meta info:
                        handler_name: Apple Alias Data Handler
                        language: eng
                    Stream 1
                    Type: audio
                    Codec: pcm_s16le
                    FourCC: sowt
                    Duration: 00:00:06
                    Bit rate: 1536 kb/s
                    Sample rate: 48000 Hz
                    Sample format: s16
                    Channel: 2
                    Meta info:
                        language: eng
                    Stream 2
                    Type: data
                    Meta info:
                        language: eng
                        timecode: 00:00:00:00
                    Dave
                    • 7. Re: Help Please! Required codec is not installed
                      Uh oh. An MJPEG video.
                      • 8. Re: Help Please! Required codec is not installed
                        daveujn Level 1
                        I take it thats not ideal then?
                        • 9. Re: Help Please! Required codec is not installed
                          A.T. Romano Level 7
                          Dave
                          Please remind me, what version of Premiere Elements, what computer operating system.
                          Please confirm your information.
                          You say that your camera is Sony HDR-CX130E. The specifications for that camera show AVCHD (MPEG4 AVC/H.264) as the video compression used by that camera. Yet, your properties readout point to video compression = MotionJPEG.
                          HDR-CX240E Specifications | Handycam Camcorders | Sony UK
                          Consequently, we need to confirm that important point.
                          Premiere Elements can have problems with the MotionJPEG video compression. The classical remedies include
                          1. Convert the MotionJPEG to another format before import into Premiere Elements project
                          or
                          2. If there is a utilities software that came with the camera, then install it with the hope that it will install the MotionJPEG codec needed for the Premiere Elements project
                          or
                          3. Go online and purchase a MotionJPEG codec.
                          Please consider, and supply more details. If any questions or need clarification on the above, please do not hesitate to ask. Supplemental details will be supplied.
                          Thank you.
                          ATR
                          • 10. Re: Help Please! Required codec is not installed
                            A.T. Romano Level 7
                            Dave
                            Please refer to my post 9 for full details. If you do not see post 9, please wait a few minutes post 9 will appear.
                            There is a link in it which may be holding up its posting by the web site. Links in thread tend to delay their appearance in the forum.
                            Thank you.
                            ATR
                            • 11. Re: Help Please! Required codec is not installed
                              daveujn Level 1
                              Hi ATR
                              Confirmation of systems
                              Premiere elements 10
                              Apple  OSX 10.11.2
                              Camera is definately Sony HDR-CX130E
                              • 12. Re: Help Please! Required codec is not installed
                                A.T. Romano Level 7
                                Dave
                                Thanks for the follow up.
                                I am still wondering how you got the file described (MotionJPEG.mov) from that Sony HDR-CX130E camera.
                                Please refer to the link with that camera's specifications that I posted already.
                                Do you have any camera literature to support recording with other than the AVCHD video compression? Or, is this clip one that was modified by you between camera recording and import into Premiere Elements?
                                Even though the clip's format is being read as "Format: QuickTime/MPEG-4/Motion JPEG 2000 format", the video codec is shown as unknown.
                                From your clip's readout:
                                The FourCC: icod seems to be the identifier for Apple Intermediate Codec. And, you are working with Premiere Elements 10 Mac on a Mac computer.
                                But, the readout cannot identify the video codec in the file. And, your video card/graphics card is not NVIDIA GeForce.
                                Is QuickTime 7 installed and updated on your computer?
                                Is this a one of a kind issue...only this one file among a batch of files from the same camera settings that will not import?
                                Please consider.
                                Thank you.
                                ATR
                                • 13. Re: Help Please! Required codec is not installed
                                  daveujn Level 1
                                  ATR
                                  The spec given refers to an HDR CX240 could they be different?
                                  Unfortunately I do not have the literature for the camera.
                                  I have quicktime version 10.4 at present.
                                  I have just started a new project with various clips from projects that I have done previously with no problems and the message below appeared.
                                  I have also given the information below for one of those clips which then does show the codec for that clip. Hope it helps.
                                  File: /Volumes/Videos/Horse.m4v
                                  Stream count: 2
                                  Duration: 00:00:17
                                  Bit rate: 1020 kb/s
                                  Meta info:
                                      minor_version: 0
                                      creation_time: 2015-10-25 09:20:35
                                      major_brand: qt
                                  Stream 0
                                  Type: audio
                                  Codec: aac
                                  FourCC: mp4a
                                  Duration: 00:00:17
                                  Bit rate: 253 kb/s
                                  Sample format: s16
                                  Channel: 2
                                  Meta info:
                                      handler_name: Core Media Data Handler
                                      language: und
                                  Stream 1
                                  Type: video
                                  Codec: h264
                                  Codec profile: High
                                  FourCC: avc1
                                  Duration: 00:00:17
                                  Width: 1280
                                  Height: 720
                                  Pixel format: yuv420p
                                  Frame rate: 30 fps
                                  Bit rate: 753 kb/s
                                  Meta info:
                                      language: und
                                  Dave
                                  • 14. Re: Help Please! Required codec is not installed
                                    A.T. Romano Level 7
                                    Dave
                                    Thanks. That screenshot is good information in narrowing down troubleshooting.
                                    The project is supposed to set the project preset automatically based on its analysis of the properties of the first file dragged to the Timeline.
                                    If it cannot, then in Premiere Elements 14/14.1, the project gives you the closest fit which may or may not be that close.
                                    Where you get into a "deal breaker" with setting mismatch is when you try to apply Stabilizer Reduction. That does not work until the project preset matches the video properties.
                                    If the program cannot set the project preset correctly, then you set it manually before you import the file into the project. Use the following scheme
                                    • Open the project to the Expert workspace, and go to File Menu/New Project and Change Settings.
                                    • In Change Settings, set the project preset to match the properties of the source media. OK out of there.
                                    • In the New Project dialog that opens, rename the project and make sure to have a check mark next to "Force Selected Project Setting on This Project". OK out of there.
                                    • Back in the Expert workspace, import your source media using Add Media/Files and Folders/Project Assets from where you drag the file to the Timeline track.
                                    Your .m4v file just described in post 13 should be compatible with your Premiere Elements Mac project, using the manually set project preset
                                    NTSC
                                    AVCHD
                                    AVCHD-LITE 720p30
                                    Whomever sets the project preset, you can verify what has been set after the file is placed on the Timeline, using Edit Menu/Project Settings/General.
                                    Although you cannot make any significant changes in the project preset that was set, that is a good place to verify what has been set.
                                    Please consider.
                                    Thank you.
                                    ATR
                                    • 15. Re: Help Please! Required codec is not installed
                                      daveujn Level 1
                                      HI
                                      Just to provide an update I have tried to add some edits to some previous footage that I have edited before as mentioned.
                                      Results were that I could Import the clips when clicking no to the above error message and I can view it ok but as soon as I add a fade the video image defaults to the media pending box.
                                      Dave
                                      • 16. Re: Help Please! Required codec is not installed
                                        daveujn Level 1
                                        ATR
                                        Have started a new project as suggested although I did not have any section for the part below.
                                        I carried on but still no change.
                                        Dave
                                        • 17. Re: Help Please! Required codec is not installed
                                          A.T. Romano Level 7
                                          Dave
                                          Apologizes for the delayed response and detouring from your Premiere Elements 10 with mention of Premiere Elements 14. My post 14 detour in detail did not change the outcome; there just was not a "Force Selected Project Setting on This Project" option in the version 10 new project dialog. If you set the Premiere Elements 10 Mac project preset for
                                          NTSC
                                          AVCHD
                                          AVCHD-LITE 720p30
                                          you were OK with my instructions (based on the properties of the questioned video that was later imported into the new project).
                                          (There is just the Video Stabilizer in 10, no Shake Reduction which replaced Shake Stabilizer which replaced Video Stabilizer later in the versions.)
                                          At this point, my major question involves your report of no change...do you mean
                                          a. You are still getting the message about mismatch of project settings with properties of this video
                                          or
                                          b. The mismatch message is gone, but you have the message " This type of file is not supported, or the required codec is not installed"
                                          Would it be possible to send a small sample of the video which is involved in this issue? You can send the sample using a shareable link obtained from Google Drive or Dropbox. I can give you the details for the Google Drive way. The important feature of the sending is that the shareable link has included in it permissions necessary to view and download the file.
                                          I need to clarify whether or not you are looking a ProRes, Apple Intermediate Files, or a regular video file.
                                          Please consider.
                                          Thank you.
                                          ATR
                                          • 18. Re: Help Please! Required codec is not installed
                                            daveujn Level 1
                                            ATR
                                            No apology needed.
                                            or
                                            Strangely I am getting both and it does not seem to make a difference if it was an M4V or .MOV file.
                                            This was the latest error message.
                                            In the meantime I will try to forward the requested file.
                                            Dave
                                            • 19. Re: Help Please! Required codec is not installed
                                              A.T. Romano Level 7
                                              Dave
                                              I think that posting sample of the file that you are actually trying to import into Premiere Elements is going to be the quickest way to resolve this issue.
                                              According to your latest screenshot, it looks like there is no .mov or .mp4 or other movie file format that is being reported under Add Media Failures. It looks like the import error is targeting .xml files - .HashTable.xml and .HashTable.xml. Is there anything more to that readout than what is shown?
                                              I do not recall .xml ever being supported by Premiere Elements. Those should be informational files, not the video files.
                                              Please let me know if you are OK with sending sample file using a Google Drive shareable link posted in your reply in your thread.
                                              Thanks.
                                              ATR
                                              • 20. Re: Help Please! Required codec is not installed
                                                A.T. Romano Level 7
                                                Dave
                                                The video audio properties of your actual problem file with .mov file extension tell me
                                                Video Format = Intermediate Codec
                                                Codec = icod (aka Apple Intermediate Codec)
                                                Frame Size = 1920 x 1080
                                                Frame Rate = 25 interlaced frames per second
                                                Bitrate (variable) = 102 Mbps
                                                Audio Format = PCM
                                                Codec ID = sowt
                                                Channels = 2
                                                Sampling Rate = 48.0 KHz
                                                Bitrate = 1536 Kbps
                                                I am strictly an Elements Windows user. And, Premiere Elements 10 and Premiere Elements 14/14.1 on Windows 7 64 bit will not import the file.
                                                If I take the file into the free HandBrake program and convert it to the H.264.mp4 @ 25 frames per second (constant), then I can import and use this version in both Premiere Elements 10 and Premiere Elements 14/14.1 on Windows 7 64 bit. I am within 99.999% certainty that the H.264.mp4 would work in your Premiere Elements 10 on your iMac.
                                                Also of note is that QuickTime Windows will not play back with video Apple Intermediate Codec, only audio. But....
                                                What is unclear to me is why these Apple Intermediate Codec.mov files are not working on your iMac with its QuickTime 7 and iMovie as part of the mix. When you try to play back your file on your QuickTime 7 installed on your iMac, do you get video as well as audio playback? I do not have any Mac experience enough to know if downloading and installing an Apple Intermediate Codec would resolve the QuickTime 7 player issue as well as that in the Premiere Elements 10 Mac program. One alternative might be to convert the Apple Intermediate Codec to Apple Pro Res 422.
                                                At this time, the issue seems to be pointing to the Apple Intermediate Codec. Still doing research to determine how the Apple deal with this - convert? If you do not get input here from Mac users, do you have any contact with Apple on this?
                                                Please consider.
                                                ATR
                                                Please consider.
                                                • 21. Re: Help Please! Required codec is not installed
                                                  daveujn Level 1
                                                  ATR
                                                  In answer to your question both audio and video is fine when played via quicktime.
                                                  Also what I do not understand is why when using the same camera some of the files are .Mov files which will not play back when rendered.And some are M4v files which seem to be ok?
                                                  I await to see if you or any Mac user has any more information.
                                                  Dave
                                                  • 22. Re: Help Please! Required codec is not installed
                                                    A.T. Romano Level 7
                                                    Dave
                                                    Thanks for the reply.
                                                    Has it always been the case....problem with files with .mov file extension and no problem with files with .mp4 file extension?
                                                    I know from the file that you sent that the .mov is using the Apple Intermediate Codec. Do you know what video codec the .mp4 is using?
                                                    Please try to find out. If it is not Apple Intermediate Codec, then that would further point to the cause of the problem = Apple Intermediate Codec.
                                                    Also, can you import your Apple Intermediate Codec.mov file into iMovie on your iMac? Can you do the same with the .mp4 file from your camera?
                                                    ATR
                                                    • 23. Re: Help Please! Required codec is not installed
                                                      Colin Holgate MVP & Adobe Community Professional
                                                      Some extra thoughts (not that I know Premiere that well, but I know QuickTime)...
                                                      One of the above file reports showed the codec to be H.264. It could be that the MP4s that work are H.264, and the MOVs that don't work are Apple Intermediate Codec.
                                                      Although Windows users are on QuickTime 7, Mac users generally are not. Only if you updated from an old version of OS X, and chose to keep QuickTime Player 7 around would you have QuickTime Player 7. Even then I think it would be using QuickTime 10. In the days where the OS X installer was a physical disc, you had QuickTime Player 7 as an optional install, and it would usually be installed into Utilities. It would only be of some use if you own a QuickTime Pro license. I still use QuickTime Player 7 when exporting video, so that I have more control.
                                                      A Mac may not have AIC, if the Mac has never had a recent iMovie, or Final Cut Pro. If that's the case you may be able to use this Pro Codecs installer:
                                                      Pro Video Formats 2.0.3
                                                      • 24. Re: Help Please! Required codec is not installed
                                                        A.T. Romano Level 7
                                                        Colin Holgate
                                                        Great post.
                                                        This is what I am suspecting.
                                                        But, the fact that Dave's QuickTime could play back his Apple Intermediate codec.mov file was not understood by me if the Apple Intermediate Codec was absent.
                                                        Is there any merit to downloading and installing just the Apple Intermediate Codec instead of the package of the Pro Codecs Installer?
                                                        Thanks for your comments for Dave. Appreciated.
                                                        ATR
                                                        • 25. Re: Help Please! Required codec is not installed
                                                          You do get Pro Res and other ones that might be useful some day, so I would just take the set.
                                                          • 26. Re: Help Please! Required codec is not installed
                                                            daveujn Level 1
                                                            Update.
                                                            Yes Codec : aac
                                                            Update
                                                            It seems that when I watch a movie clip first before I export to elements 10 using quicktime it converts it first and then I can import and edit with no problem (at time of writing this) But if I import to elements 10 directly from my external hard drive then I cannot. Suggesting that quicktime needs to convert video first.
                                                            I then did a test using a Canon DSLR which also used .MOV files and imported directly from the external hard drive to elements 10 but this time there were no problems and the info on the codec was h264.
                                                            Question: If all footage with .MOV files have to be converted by quicktime why doesn't the Canon DSLR
                                                            Dave
                                                            • 27. Re: Help Please! Required codec is not installed
                                                              AAC is the audio codec. The video codec would usually be H.264, though it may be shown as AVC, which could be what you meant to write.
                                                              I have seen cases where a video file would not open in some programs, but just opening in QuickTime Player, and doing a Save As, would give a file that worked.
                                                              • 28. Re: Help Please! Required codec is not installed
        A.T. Romano Level 7
        Dave
        As Colin points out - AAC is an audio compression format. Apple Intermediate Codec is video compression format being used by your problem .mov files. You have written that the files from the Sony with the .mp4 file extension are working OK for you while the .mov are not. The reason for the .mp4 working may relate to whether or not it also uses that Apple Intermediate Codec. It is an important supplemental piece of the information at this point..
        Where did you check to find out what video compression that the .mp4 file uses? Colin has already pointed to some video compression possibilities for the .mp4. If it does use Apple Intermediate Codec, you will probably see Video Format = Intermediate Codec and the video codec identified as icod. If it is not using the Apple Intermediate codec, then you look for video compression formats such a those that Colin mentioned. Look for H.264, avi1, MPEG2 AVC/H.264, and the like.
        What is the model of the Canon DSLR that you used and did not run into any Apple Intermediate Codec.mov issues. This points us back to the Sony for other look at its recording and the transfer of those files to your Mac computer.
        Since Colin has mentioned his expertise in matters QuickTime, please follow up with him on that.
        Please consider.
        Thank you.
        ATR
        • 29. Re: Help Please! Required codec is not installed
        I doubt that any MP4 file would have AIC as the codec. Usually it would either be the MPEG-4 video codec, or H.264 (or the same thing with a different name).
        It also seems a little unusual that Canon would do anything that then requires QuickTime, but not out of the question. I mean, Apple used to sell Canon hardware as if it had been made by Apple, so they do have a relationship.
        • 30. Re: Help Please! Required codec is not installed
        A.T. Romano Level 7
        Colin
        Thanks for the follow ups. Looking forward to Dave's confirmations, details, and results.
        I am adding on to this reply after posting the original one line above.
        Based on your knowledge of QuickTime 7, how do you envision the QuickTime 7 software essentially re-encoding a file that it is supposed to be playing back not re-encoding from H.264.mov to Apple Intermediate Codec.mov? Is there something different about QuickTime 7 on Mac computer as compared to QuickTime 7 installed on Windows computer?
        ATR
        • 31. Re: Help Please! Required codec is not installed
        daveujn Level 1
        My mistake. It was the audio codec
        I also could not install the software from pro video formats as Final cut pro, motion, or compressor were not found.
        Dave
        • 32. Re: Help Please! Required codec is not installed
        daveujn Level 1
        A.T. Romano wrote:
        "Where did you check to find out what video compression that the .mp4 file uses?"
        I used a third party software called media info.
        "What is the model of the Canon DSLR"
        Canon 500D DSLR
        Just to clarify previous information.
        m4v files
        Format; Quicktime/MPEG-4/Motion JPEG 2000 Format
        Video codec; h264
        Audio codec; aac
        FourCC; mp4a
        .MOV Files
        FormatVideo codec; Unknown codec
        Audio codec; ppm_s16le
        FourCC; icod
        Canon .MOV Files
        Video codec; h264
        FourCC; avc1
        Hope this helps.
        Dave
