2 Replies Latest reply on Nov 16, 2015 9:35 AM by tlumbis
    Graphic Line Anchors...
    tlumbis
      The script below from GitHub (Graphic Lines · fabiantheblind/auto-typo-adbe-id Wiki · GitHub) creates the path shown below...
      The anchor location for each point matches the position of the point before it.
      I want to create a path made only of straight lines and have been trying, unsuccessfully, to either remove the anchors or to make the anchor positions match the position of the point they're drawn from.
      Does anybody have any suggestions?
      Thanks very much for any help.
      var data = {
         "pw":100,
         "ph":100,
         "anchors":[
        [  0,50],
        [ 10,60],
        [ 20,40],
        [ 30,60],
        [ 40,40],
        [ 50,60],
        [ 60,40],
        [ 70,60],
        [ 80,40],
        [ 90,60],
        [100,50]
         // we need a doc
         // use pw and ph from data
         var doc = app.documents.add({
        documentPreferences:{
        pageHeight:data.ph,
        pageWidth:data.pw
         // the page is already there
         var page = doc.pages.item(0);
         // create a graphicLine
         var gl = page.graphicLines.add();
         // loop thru the data.anchors
         for(var i in data.anchors){
         var point = gl.paths[0].pathPoints[i];
        * a graphicLine always has 2 pathpoints
        * so we need to add points only from the third
        * anchor from the data object
         if(i < 2){
        point.anchor = data.anchors[i];
        }else{
        point = gl.paths[0].pathPoints.add();
         if((i != data.anchors.length - 1)&& i!=0)
        point.rightDirection = data.anchors[i-1];
        point.leftDirection = data.anchors[i];
