7 Replies Latest reply on Apr 29, 2016 3:57 AM by tpk1982
    Need to select ALL tables
    piab59734901 Level 1
      I import Word documents in InDesign CC, wich contains several tables.
      I need to select ALL tables and then change the size of the text inside the cells and I need to change the table strokes inside and the table-border.
      I know how to install a script in InDesign – though I have not yet tried to work with a script ...
      ... hope my first time will be succesfull :-))))
      Hope that somebody can help me.
      Regards,
      Pia (graphic designer)
        • 1. Re: Need to select ALL tables
          tpk1982 Level 4
          hi..
          try this
          change the values as your requirement:
          app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().paragraphs.everyItem().pointSize = "3pt";
          app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().topInset = "3pt";
          app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().bottomInset = "3pt";
          app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().leftInset = "3pt";
          app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().rightInset = "3pt";
          app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().bottomEdgeStrokeWeight = "0.5";
          app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().topEdgeStrokeWeight = "0.5";
          app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().leftEdgeStrokeWeight = "0.5";
          app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().rightEdgeStrokeWeight = "0.5";
          • 2. Re: Need to select ALL tables
            It works :-)))))) thanks to you I just run my first script ever :-)))))
            Looking forward to changing the sizes.
            You are awesome – thanks a million :-))))) and have a great day.
            Regards,
            Pia
            • 3. Re: Need to select ALL tables
              tpk1982 Level 4
              Hey Pia,
              Which size need to change?
              Also please give correct answer if it works fine.
              Have a nice day
              karthi
              • 4. Re: Need to select ALL tables
                Hi Karthi
                By sizes I mean the text-pt-sizes and the stroke-sizes (the blue text) :-))
                I have one problem though – the table bottomEdgeStroke is different from table to table. Ex. in a 4 row table I may only need a stroke on the bottomEdgeRIGHT row. Other times 3 rows or 2 rows.
                Think that the solution may bee a script that SELECTS ALL TABLES and then I can apply an InDesign TableStyle?
                Is that possible?
                Sorry – I thought I gave a correct answer above :-))) your script still works fine :-))))
                You solved the problem I had :-)))
                Regards,
                Pia
                • 5. Re: Need to select ALL tables
                  tpk1982 Level 4
                  Hi Pia,
                  Try this below script. It will ask you the values (take as points) to change. I don't think table style give solution.
                  //changing measurement as points
                  app.activeDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.POINTS;
                  app.activeDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.POINTS;
                  var myText=prompt("PLEASE ENTER YOUR TEXT POINT SIZE","")
                  var myStroke=prompt("PLEASE ENTER YOUR TABLE STROKE VALUE","")
                  var myBottomStroke=prompt("PLEASE ENTER YOUR TABLE BOTTOM STROKE VALUE","")
                  //changing text point size
                  app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().paragraphs.everyItem().pointSize = myText;
                  //changing text stroke size
                  app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().bottomEdgeStrokeWeight = myBottomStroke;
                  app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().topEdgeStrokeWeight = myStroke;
                  app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().leftEdgeStrokeWeight = myStroke;
                  app.activeDocument.stories.everyItem().tables.everyItem().cells.everyItem().rightEdgeStrokeWeight = myStroke;
                  Please let me know if this is fine.
                  Note: i removed the inset value coding, hope you don't require that.
                  Regards,
                  Karthi
                  • 6. Re: Need to select ALL tables
                    vidhyar34646163
                      I have same issue to select all the tables. I don't need to change table styles ,But need to select all the tables simultaneously. How to do tat? I need like,
                    app.activeDocument.stories.everyItem().tables.everyItem().getElements()[i].select();
                    • 7. Re: Need to select ALL tables
                      tpk1982 Level 4
                      see this thread..hope this is useful
                      Select table using script
