3 Replies Latest reply on Nov 18, 2015 5:29 AM by rickg76305781
    Applescript: How do I attach a script to an event??
    rickg76305781 Level 1
      I have an applescript that creates PDF and uploads it to a specific destination. (see below)
      I want to invoke this script every time the user "saves" the doc.
      I am a novice when it comes InDesign applescripting...I don't know if its possible to attach a script to the "save" function??
      I am guessing I need to incorporate an event listener?? again i am guessing. perhaps there is a better way? attach the script to key combo Command-s??
      the objective is to give the user the option to send a PDF every time they save a document.
      Here is the script thus far:
      set _ExportPDF to (display dialog "Send Proof?" with icon caution buttons {"Cancel", "PDF"} default button 2)
      tell application "Adobe InDesign CS6"
        if button returned of _ExportPDF is "PDF" then
        set myFolder to "PDFProofs:"
        set _dest to myFolder as Unicode text
        set screenSettings to PDF export preset "[High Quality Print]"
        set page range of PDF export preferences to all pages
        set docName to name of document 1
        if docName ends with ".indd" then
        set docName to text 1 thru -6 of docName
        end if
        export document 1 format PDF type to (_dest & docName & ".pdf") using screenSettings without options
        if modified of active document is true then
        tell active document to save
        close document 1
        end if
                 tell PDF export preferences
                     set view PDF to true
                 end tell
        end tell
        end if
      end tell
        • 1. Re: Applescript: How do I attach a script to an event??
          ok i see now where i can save the script as a "start-up" script (i.e. applications>adobe indesign>scripts>startup scripts) but how do i make the script run on "save" the doc??
          anyone?? bueller? anyone??
          • 2. Re: Applescript: How do I attach a script to an event??
            greenrookie Level 2
            The easiest way is to set keyboard shortcut Command-S to your script.
            I also set various save/package scripts to common keyboard shortcuts.
            gr
            • 3. Re: Applescript: How do I attach a script to an event??
              i figured it out.
              an event listener needs to be placed in the InDesign startup scripts folder
              that script listens for the Save events... specifically: afterSave, afterSaveAs, afterSaveACopy
              (it could listen for other events as well but i am only interested in the after save functions)
              i wanted to trigger my PDF upload script after any of those events...so the script was very simple
                set myEventNames to {"afterSave", "afterSaveAs", "afterSaveACopy"}
                repeat with myEventName in myEventNames
                make event listener with properties {event type:myEventName, handler:"Macintosh HD:Applications:Adobe InDesign CS6:Scripts:Scripts Panel:Samples:AppleScript:PDFUpload.scpt"}
                end repeat
              end tell
              handler = the path to my PDFUpload applescript
              done and done
              thank you everyone for your help!! R
