7 Replies Latest reply on Nov 27, 2017 8:51 PM by Charlie Arehart
    Coldfusion 11 on windows 10
    izabelm34768934
      I am running ColdFusion 11 on Windows 10. My http://localhost pulls up my windows page but when I added cfm files to wwwroot it won't run anymore and I get this error code.
      I am simply using notepad and save my code files as cfm.
      Help me
      HTTP Error 404.3 - Not Found
      The page you are requesting cannot be served because of the extension configuration. If the page is a script, add a handler. If the file should be downloaded, add a MIME map.
      Most likely causes:
      • It is possible that a handler mapping is missing. By default, the static file handler processes all content.
      • The feature you are trying to use may not be installed.
      • The appropriate MIME map is not enabled for the Web site or application. (Warning: Do not create a MIME map for content that users should not download, such as .ASPX pages or .config files.)
      • If ASP.NET is not installed.
      Things you can try:
      • In system.webServer/handlers:
        • Ensure that the expected handler for the current page is mapped.
        • Pay extra attention to preconditions (for example, runtimeVersion, pipelineMode, bitness) and compare them to the settings for your application pool.
        • Pay extra attention to typographical errors in the expected handler line.
      • Please verify that the feature you are trying to use is installed.
      •   Verify that the MIME map is enabled or add the MIME map for the Web site using the command-line tool appcmd.exe.
        1. To set a MIME type, use the following syntax: %SystemRoot%\windows\system32\inetsrv\appcmd set config /section:staticContent /+[fileExtension='string',mimeType='string']
        2. The variable fileExtension string is the file name extension and the variable mimeType string is the file type description.
        3. For example, to add a MIME map for a file which has the extension ".xyz": appcmd set config /section:staticContent /+[fileExtension='.xyz',mimeType='text/plain']
          Warning: Ensure that this MIME mapping is needed for your Web server before adding it to the list. Configuration files such as .CONFIG or dynamic scripting pages such as .ASP or .ASPX, should not be downloaded directly and should always be processed through a handler. Other files such as database files or those used to store configuration, like .XML or .MDF, are sometimes used to store configuration information. Determine if clients can download these file types before enabling them.
      • Install ASP.NET.
      • Create a tracing rule to track failed requests for this HTTP status code. For more information about creating a tracing rule for failed requests, click here.
      Detailed Error Information:
      Module   StaticFileModule
      Notification   ExecuteRequestHandler
      Handler   StaticFile
      Error Code   0x80070032
      Requested URL   http://localhost:80/universityApp/main.cfm
      Physical Path   C:\inetpub\wwwroot\universityApp\main.cfm
      Logon Method   Anonymous
      Logon User   Anonymous
