0 Replies Latest reply on Nov 17, 2015 12:17 AM by souravp7069365
    Unable to build .exe installer
    souravp7069365
      Hy there,
      Our client provided us a .p12 certificate with password.
      I am using this certificate for our flex application. When I am trying to build the application, .air and .airi installer are successfully build but in the case of .exe file the build process getting failed and showing the following error "Certificate in C:\****\****\natureair.p12 could not be used to sign setup.msi".
      And then I am trying to build the .exe file from .air installer with adt command. but though this .exe allows to install the application but prevents to login into the application.
      I really would appreciate any help in this issue,
      Kind regards
