• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
odbc sql server 2014 coldfusion 11 mismatch error
New Here ,
Nov 17, 2015 Nov 17, 2015
I have installed 64 bit versions of SQL server express 2014 and ColdFusion 11 developer edition 64 bit in a Windows 8.1 machine that never had earlier versions of these applications installed.  I successfully created the SQL Server ODBC driver (64 bit) in Windows.  I then tried to create in ColdFusion the ODBC Socket connector.  It recognized the existence of the Windows ODBC configurations (it was in the drop down box).  Yet when I tried to complete the process I got the following error message:
java.sql.SQLException: [Macromedia][SequeLink JDBC Driver][ODBC Socket]internal error: The specified DSN contains an architecture mismatch between the Driver and Application
The root cause was that: java.sql.SQLException: [Macromedia][SequeLink JDBC Driver][ODBC Socket]internal error: The specified DSN contains an architecture mismatch between the Driver and Application
Thank you in advance for any help!
Views
404
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guide ,
Nov 27, 2015 Nov 27, 2015
You should not have to use the ODBC driver to connect to SQL Server.  The built-in Microsoft SQL Server driver should work fine with SQL Server Express.
-Carl V.
Votes
Translate
Translate
Report
Report
Advocate ,
Nov 30, 2015 Nov 30, 2015
LATEST
Yes, use the built in Microsoft SQL Server driver.
The original CFMX (CF6 I believe) used JDBC-->ODBC-->MS-SQL and it was V.E.R.Y...S.L.O.W.! I would be afraid that using an ODBC socket connector would set you back to the slow days of CF. I have not found any disadvantage of using the native Microsoft SQL Server driver.
Votes
Translate
Translate
Report
Report
Resources
Documentation
