I can't sign "Adobe AIR_64" with codesign the way I can without any problems with Air19.
Here's the error I receive:
... .app/Contents/Frameworks/Adobe AIR.framework: code object is not signed at all
In subcomponent: ... .app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR_64
Can anyone please help me out?
OS: OS X latest El Capitan
I have no problem signing AIR19's AIR framework binaries
Edit: target is native bundle, OS X
Okay, I figured it out.
If you're just signing the "Adobe AIR.framework" directory alone, it's not enough, you have to force signing of the "Adobe AIR_64" file first in order for codesign to finish the task without errors.
Cheers
Hi
I'm having the same problem trying to sign the framework and its contents. Everything I try has failed and I always get errSecInternalComponent. Could you share an example terminal input to sign the framework?
Many thanks
Simon
