1 Reply Latest reply on Nov 17, 2015 5:49 AM by resdesign
    Different paths ways depending on which two buttons they have selected
    196louiseford
      Basically, I have a tick box type of interaction where I would only want the user to press two out of the four buttons to proceed onto the next page. However depending on which two buttons they choose will take you down a different route. Is there anyway of doing this on Edge Animate?
      Thank you in advance,
      Louise
        • 1. Re: Different paths ways depending on which two buttons they have selected
          resdesign Adobe Community Professional & MVP
          Yes, use variables and check them.
          Example
          // initialize your variable here
          var selected1 = 1;
          var selected2 = 1;
          On your click event check the variable value and then reset the variable for next clicks.
          // this goes on the 2 first choices
          sym.$("button1").bind('click',function(){
               selected1 = 0;   // your variable is changed to 0 when the conditional checks variable from the 2 button choices
               if(selected1 == 0 && selected2 == 0){
                     // ADD YOUR CODE FOR CLICK EVENT HERE
                      selected1 = 1;  // when you click your variable will be changed to 1
          // this goes for the 2 other choices
          sym.$("button3").bind('click', function(){
                 selected2 = 0;  // your variable is changed to 0 when the conditional checks variable from the 2 button choices
                selected2 = 1;  // when you click your variable will be changed to 1
