1 Reply Latest reply on Apr 3, 2009 11:11 AM by MrPoptart
    minWidth and minHeight not working for standalone swf
    MorganEngel
      First, you have to set your projects settings to not build the HTML template dir. this is done by right clicking on the project, going to properties, selecting Flex Compiler on the left, then unchecking the "Generate HTML wrapper file" checkbox.
      The goal is to use fscommand to build a fullscreen file with content in the center. I have attached code with two application tags, one commented out. first, build it as is. You'll see the content is centered. Then, hit escape, you'll see that the size of the window is less than 1024x768. If you load the other application tag, you'll see that the content window is the right size, but the fullscreen is aligned top left.
      I'll take any suggestions!
      Thanks.
