3 Replies Latest reply on Nov 17, 2015 6:20 AM by nezarov
    text box not scrolling.
    WilliamRhoades1 Level 1
      I'm currently having issues with the text boxes
      I have two text boxes on stage.
      one is an input type.
      the other is a dynamic type, Multi line , scrolling enabled, and a scroll bar attached.
      Both are set to use device fonts.
      when I run the code the text doesn't scroll and the newer lines aren't visible after it reaches outside the view-able space. Unless the text is filled both horizontally and vertically.
      btn.addEventListener(MouseEvent.CLICK, snd);
      function snd (e:MouseEvent):void{
      word.text += ((input.text) + "\n");
      here is a download of the FLA so you can see what I did exactly.
      https://www.dropbox.com/s/tzha43452q0g1x3/fixit.fla?dl=0
      The problem is that if I hit clear, then populate the box it won't scroll.
