2 Replies Latest reply on Nov 18, 2015 2:05 AM by K.Daube
    Testing escripts with menus
    K.Daube Level 1
      Hello friends, I'm back to my project.
      After installing "everything needed" on a new laptop I can now run ESTK as intended and hence want to use breakpoints etc.
      But my breakpoints do'nt halt the script:
      • In the script I have defined a breakpoint in a function some levels down
      • FM is open with a document the script will work on.
      • I start the script in ESTK. It creates a menu and then stops (OK)
      • Selecting the appropriate menu item, the script runs
      • A message appears. it is somewhere prior to the breakpoint.
      • Another message appears - this is way after the breakpoint.
      • So the script did not stop at the breakpoint!
      How can I run the script from the menu to the breakpoint and then tip-toe through the script?
      I have not found any hint in the JavaScript Tools Guide.
        • 1. Re: Testing escripts with menus
          Klaus Göbel Level 3
          Hi Klaus,
          let me guess:
          - Your new windows is running windows 8.1 ?
          - you are using include-files? (where your breakpoints are placed?)
          That's what happened to me.
          You have to select for every single include-file FrameMaker and not ExtendScript Toolkit. On Windows 7 I didn't have to do that.
          You can try to force that, by starting the script with F10/F11. That SOMETIMES works for me.
          On Windows 8.1 ESTK also ignors #target framemaker.
          • 2. Re: Testing escripts with menus
            K.Daube Level 1
            Thanks Klaus, for thinking...
            In the evening with some spacial and timely distance to the computer I had this idea:
            • Insert the call of the (otherwise menu invoked) function directly before the menu set up (DefineMenus();)
            • Place the breakpoint
            • Run the script
            After commenting out messages (which in my case try to create a window - which was not accepted) the script halted at the breakpoint.
            And now the solution for the real problems are waiting...
