5 Replies Latest reply on Nov 18, 2015 8:13 AM by Todd_Kopriva
    I think I broke it...blank layers?
    canilucas
      I have a super sillious project file. Probably way to many layers, over 1000, and when I went an added like 1001, all the layers disappeared... well the trimmed area for each did. I've created multiple comps, to get around the issue, but is there a setting/preference that I met, broke, killed, corrupted for why this is happening?
        • 1. Re: I think I broke it...blank layers?
          Dave LaRonde Level 6
          No clue what's wrong -- insufficient information.  But here's a stab in the dark: If you're running AE CC 2015, upen the project file in AE CC 2014; you would be on the cloud, and yu can get it if you don't have it.
          • 2. Re: I think I broke it...blank layers?
            There is a point where you run out of layers. It looks like you have reached it. AE can handle a bunch of layers but if you are putting 1000 or more in a single comp I suspect that you may be trying to edit more than a shot or a short sequence in AE. That's not a practical workflow.
            If you are working on a shot that has more than 1000 elements then it's probably a good idea to group them into sections (pre-comps) then nest the sections together to edit the final shot.
            • 3. Re: I think I broke it...blank layers?
              canilucas Level 1
              Thanks Dave for responding. I think I found the answer in the a creative cow thread. After Effects can't, doesn't, won't display the layers viewable trim sections past a certain number.
              • 4. Re: I think I broke it...blank layers?
                canilucas Level 1
                Rick
                Thanks for the response. I found this same thing in a Creative Cow article. That's what I did, I used pre-comps to group the word art into manageable chunks. I realize it wasn't a practical workflow, but made sense to me at the time.
                • 5. Re: I think I broke it...blank layers?
                  Todd_Kopriva Level 8
                  It's not exactly that you "run out of layers". The layers are still there (i.e., their images should show up in the Composition panel). The bug is that the Timeline panel can't draw the representations of that many layers in list view. The limit is ~30,000 pixels of vertical height; since each layer takes a little more than 20 pixels vertically in the Timeline panel, that works out to somewhere between 1,000 and 2,000 layers to trigger the problem.
                  To fix this bug requires rewriting how we draw list views. This is not the highest priority right now because typical compositions don't have that many layers, and the ones that do tend to use precompositions to manage them.
                  If this is getting in your way, you can influence the priority of fixing this bug by submitting a report here:
                  http://adobe.ly/ReportBug
