1 Reply Latest reply on Nov 18, 2015 3:34 AM by christinadarcy67@gmail.co
    Dreamweaver 2015 CC - extension cannot be installed - version 6 or later
      Hello,
      I am running PC with  windows 8.1 64-bit
      I have loaded cc 2015 dreamweaver and the extension manager, both downloaded from Adobe Creative Cloud.
      REF: Adobe Dreamweaver CC 2015.0 ~ BUILD 7714
      If I try and load an extension I get the error "this extension can not be installed, it requires dreamweaver version 6 or greater."
      I was trying to load a .zxp extension from PVii.
      I have reloaded DW and the EM 3 times now with no joy.
      I see this tread here but I see this person was running windows 7, thus it didn't really help me.
      https://forums.adobe.com/thread/1317178
      i see in the above post it is mentioned
      " It seems that Extension Manager doesn't find Dreamweaver.
      Here is a way to check whether dreamweaver 13 is installed or not:
      (1)install "Extendscript Toolkit CC" from creative cloud
      (2)launch it, input "BridgeTalk.__diagnostics__;" (exclude double-quotes)
      (3)click "Debug->Run", you will get  informations in "Javascript Console" window at the top right.
      (4)check whether dreamweaver-13.0 have been listed under "Targets" section, and they have correct path and exename. You can also paste these output information here. "
      I have downloaded and run the Extendscript Toolkit CC and it give the results below.
      Extendscript Toolkit CC START
      Result: BridgeTalk Diagnostics
        Info:
        Name = estoolkit-4.0
        Status = PUMPING
        Group = cs
        Path = C:\Program Files (x86)\Adobe\Adobe ExtendScript Toolkit CC\ExtendScript Toolkit.exe
        Version = 2.0
        Build = ES 4.5.5
        Next serial number = 40
        Logging: = OFF
        Now = 08:50:56
        Message Version = 2.05
        Authentication = ON
        Digest = ON
        Thread: estoolkit-4.0#thread
        Avg. pump interval = 47ms
        Last pump = 94ms ago
        Ping: 7
        ECHO_REQUEST: ECHO_RESPONSE
        Timeout = undefined
        Handler = undefined
        STATUS: PUMPING
        Timeout = undefined
        Handler = undefined
        MAIN: MAIN
        Timeout = undefined
        Handler = installed
        LAUNCHED: LAUNCHED
        Timeout = undefined
        Handler = installed
        DIAGNOSTICS: DIAGNOSTICS
        Timeout = undefined
        Handler = installed
        INFO: INFO
        Timeout = undefined
        Handler = installed
        SETUPTIME: thread=0ms, left=15ms
        Timeout = undefined
        Handler = undefined
        Instances: 3
        estoolkit-4.0#dbg:
        msg[08:50:56]: 00000035
        @BT>Version = 2.05
        Target = estoolkit-4.0#dbg
        Sender = estoolkit-4.0#dbg
        Sender-ID = localhost:win5828
        Timeout = 08:50:57
        Type = Ignore
        Response-Request = Timeout
        Headers = (no headers)
        Timestamp = 08:50:56
        Serial-Number = 35
        Received = undefined
        Result = undefined
        Error = undefined
        Body = (empty)
        Incoming: 1
        Outgoing: 0
        Handler: 9
        ExtendScript = for all messages
        Error = for only msg #25
        Error = for only msg #27
        Error = for only msg #31
        Result = for only msg #35
        Error = for only msg #35
        Timeout = for only msg #35
        Result = for only msg #37
        Error = for only msg #37
        estoolkit-4.0#estk:
        msg[08:50:56]: 00000037
        @BT>Version = 2.05
        Target = estoolkit-4.0#estk
        Timeout = 09:00:56
        Type = Debug
        Response-Request = Result Error
        Serial-Number = 37
        Result = undefined
        Error = undefined
        Body: 107 bytes
        Text = <get-properties engine="main" object="$.global" exclude="undefined,builtin,prototype" all="true" max="20"/>
        Incoming: 1
        Outgoing: 0
        Handler: 1
        estoolkit-4.0: (main)
        Incoming: 0
        Outgoing: 0
        Handler: 1
        Targets: 3
        Connector = PCD
        Installed: 0
        Running: 0
        dreamweaver-16.0.64:
        Path = C:\Program Files\Adobe\Adobe Dreamweaver CC 2015\Dreamweaver.exe
        Display Name = Adobe Dreamweaver CC 2015
        MsgAuthentication = ON
        MsgDigest = ON
        ESTK = OFF
        Status = (not running)
        ExeName = Dreamweaver.exe
        estoolkit-4.0: PUMPING
        Group = cs
        Display Name = ExtendScript Toolkit CC
        MsgDigest = ON
        ESTK = ON
        Status = PUMPING
        Info:
        Group = cs
        Version = 2.0
        Build = ES 4.5.5
        Next serial number = 44
        Logging: = OFF
        Now = 08:50:56
        Authentication = ON
        Digest = ON
        Last pump = 313ms ago
        Ping: 7
        Timeout = undefined
        Handler = undefined
        STATUS: PUMPING
        Timeout = undefined
        Handler = undefined
        MAIN: MAIN
        Timeout = undefined
        Handler = installed
        LAUNCHED: LAUNCHED
        Timeout = undefined
        Handler = installed
        Timeout = undefined
        Handler = installed
        INFO: INFO
        Timeout = undefined
        Handler = installed
        Timeout = undefined
        Handler = undefined
        ExeName = ExtendScript Toolkit.exe
        exman-7.0:
        Group = cs
        Path = C:\Program Files (x86)\Adobe\Adobe Extension Manager CC\Adobe Extension Manager CC.exe
        Display Name = Adobe Extension Manager CC
        MsgDigest = ON
        ESTK = OFF
        BundleID = com.adobe.exman
        ExeName = Adobe Extension Manager CC.exe
        Installed: 2
        Running: 1
        Groups: 143
        cs3:
        acrobat-8.0
        aftereffects-8.0
        soundbooth-1.0
        bridge-2.0
        contribute-4.5
        devicecentral-1.0
        dreamweaver-9.0
        encore-3.0
        estoolkit-2.0
        fireworks-9.0
        flash-9.0
        illustrator-13.0
        indesign-5.0
        indesignserver-5.0
        incopy-5.0
        photoshop-10.0
        premiere-3.0
        premierepro-3.0
        stockphotos-1.5
        audition-3.0
        cs4:
        acrobat-9.0
        aftereffects-9.0
        soundbooth-2.0
        bridge-3.0
        contribute-5.0
        devicecentral-2.0
        dreamweaver-10.0
        encore-4.0
        estoolkit-3.0
        fireworks-10.0
        flash-10.0
        illustrator-14.0
        indesign-6.0
        indesignserver-6.0
        incopy-6.0
        photoshop-11.*
        premierepro-4.0
        audition-4.0
        ame-1.0
        exman-2.0
        cs5:
        acrobat-9.0
        aftereffects-10.0
        soundbooth-3.0
        bridge-4.0
        contribute-6.0
        devicecentral-3.0
        dreamweaver-11.0
        encore-5.0
        estoolkit-3.5
        fireworks-11.0
        flash-11.0
        illustrator-15.0
        indesign-7.0
        indesignserver-7.0
        incopy-7.0
        photoshop-12.*
        premierepro-5.0
        audition-5.0
        ame-2.0
        exman-3.0
        flashbuilder-4.0
        flashcatalyst-1.0
        ts1:
        captivate3-en_us
        captivate3-fr_fr
        captivate3-it_it
        captivate3-ja_jp
        captivate3-es_es
        captivate3-de_de
        ts2:
        captivate-4.0
        el2:
        captivate-5.0
        as1:
        acrobat-10.0
        ts3:
        robohelp-9.0
        framemaker-10.0
        cs55:
        aftereffects-10.5
        audition-4.0
        bridge-4.1
        contribute-6.1
        devicecentral-3.5
        dreamweaver-11.5
        encore-5.1
        estoolkit-3.6
        fireworks-11.1
        flash-11.5
        illustrator-15.1
        indesign-7.5
        indesignserver-7.5
        incopy-7.5
        photoshop-55.*
        premierepro-5.5
        ame-2.5
        exman-5.5
        flashbuilder-4.5
        flashcatalyst-1.5
        switchboard-2.0
        el25:
        captivate-5.5
        cs60:
        aftereffects-11.0
        audition-5.0
        bridge-5.*
        contribute-6.88
        devicecentral-4.0
        dreamweaver-12.0
        encore-6.0
        estoolkit-3.8
        fireworks-12.0
        flash-12.0
        illustrator-16.*
        indesign-8.0
        indesignserver-8.0
        incopy-8.0
        photoshop-60.*
        premierepro-6.0
        ame-6.0
        exman-6.0
        flashbuilder-4.52
        switchboard-2.0
        prelude-1.0
        speedgrade-6.0
        el60:
        captivate-60.*
        ts4:
        robohelp-10.0
        framemaker-11.0
        cs70:
        audition-6.0
        bridge-6.*
        dreamweaver-13.0
        encore-7.0
        fireworks-13.0
        flash-13.0
        illustrator-17.*
        indesign-9.*
        indesignserver-9.0
        incopy-9.*
        photoshop-70.*
        premierepro-7.0
        ame-7.0
        exman-7.0
        flashbuilder-5.0
        prelude-2.0
        estoolkit-4.0
        aftereffects-12.0
        el70:
        captivate-70.*
        cs70:
        switchboard-3.*
        cs90:
        bridge-6.*
        photoshop-90.*
        estoolkit-4.0
      Extendscript Toolkit CC END
      LOG FILE GENERATION  START **************
      I have also followed this
      Please generate log file
      1. Create a file named "ExManCoreLibLog.YES" in "C:\Users\<YourUserName>\AppData\Roaming\Adobe\Extension Manager CC\Log" folder. If this folder doesn't exist, you can create it first. Please note that Windows will hide file extension at default, so please click "Organize" -> "Folder and search options" -> "View" in Windows Explorer, then uncheck "Hide extensions for known file types" to make sure this file doesn't has hidden ".txt" or other extensions.
      2. Launch Extension Manager CC.
      3. After the launch finished, close Extension Manager CC.
      4. The log file ExManCoreLibrary.log can be found in the same folder.
      The result from my log file are as
      ********************* Log File Results Start ***************************
      [Error] Wed Nov 18 09:00:32.592 2015 (ExtensionBase.cpp, 129) -CExtensionBase::validateExtension: searchAllSupportedProducts() failed, status = -411!
      [Error] Wed Nov 18 09:00:32.608 2015 (ExtensionBase.cpp, 607) -CExtensionBase::install: validateExtension() failed for zxp C:\Users\******\Documents\Dreamweaver extensions 2015\pvii 2015\P7_PowerToys_191.zxp, status = -411!
      ********************* Log File Results END ***************************
      LOG FILE GENERATION  END    **************
      LOG OUT Start    **************
      I have also tried closing everything and logging out and logging backin to cloud but that did not make a difference. "I closed them went into Creative Cloud.>  Preferences.>  Logout."
      LOG OUT End    **************
      I am grateful for any input
      regards
      Christina
