2 Replies Latest reply on Nov 19, 2015 12:52 AM by sarit68219861
    Save files as jpeg and close script
    sarit68219861
      Hi all,
      I am very new to scripting (as of this morning) and struggling to get my head round whether the following is possible. Apologies if I am missing something basic.
      I would like to be able to have a script which will open a jpeg, insert the file name on to the image, save as a jpeg and close.
      I have managed to find examples of this and currently have a script which will open the image, insert the file name and save the file - but as a photoshop document. I am also very keen on the images closing as I need to process at around 200 images at a time and and at the moment can only do a few at a time.
      I have inserted what i have so far below...Any help would be appreciated.
      Description:
      This script is a template script that will
      open and process a folder of images
      // enable double clicking from the
      // Macintosh Finder or the Windows Explorer
      #target photoshop
      // Make Photoshop the frontmost application
      // in case we double clicked the file
      app.bringToFront();
      // SET-UP //
      // A list of file extensions to skip, keep them lower case
      gFilesToSkip = Array( "db", "xmp", "thm", "txt", "doc", "md0", "tb0", "adobebridgedb", "adobebridgedbt", "bc", "bct" );
      // Pops open a dialog for the user to
      // choose the folder of documents to process
      var inputFolder = Folder.selectDialog("Select a folder of documents to process");
      // MAIN //
      // Open Folder of Images
      OpenFolder();
      // show the path to an output folder
      alert(outputFolder);
      // FUNCTIONS //
      // Given the a Folder of files, open them
      function OpenFolder() {
      var filesOpened = 0;
      var fileList = inputFolder.getFiles();
      for ( var i = 0; i < fileList.length; i++ ) {
      // Make sure all the files in the folder are compatible with PS
      if ( fileList[i] instanceof File && ! fileList[i].hidden && ! IsFileOneOfThese( fileList[i], gFilesToSkip )) {
      open( fileList[i] );
      filesOpened++;
      // Put all your processing functions... //
      var originalUnits = app.preferences.rulerUnits
      app.preferences.rulerUnits = Units.PIXELS
      app.foregroundColor.rgb.red = 255
      app.foregroundColor.rgb.green = 255
      app.foregroundColor.rgb.blue = 255
      // add the pixel position for the left side of your text block below
      var textLeftPosition= 260
      // add the pixel position for the bottom of your text block below
      var textBottomPosition= 260
      var typeLayer = app.activeDocument.artLayers.add();
      typeLayer.name = app.activeDocument.name;
      typeLayer.kind = LayerKind.TEXT;
      typeLayer.textItem.size = 48;
      typeLayer.textItem.position = [textLeftPosition, textBottomPosition];
      var layerName = typeLayer.name
      typeLayer.textItem.contents = layerName;
      app.activeDocument.close(SaveOptions.SAVECHANGES);
      // ...in the area between these two comments. //
      // given a file name and a list of extensions
      // determine if this file is in the list of extensions
      function IsFileOneOfThese( inFileName, inArrayOfFileExtensions ) {
      var lastDot = inFileName.toString().lastIndexOf( "." );
      if ( lastDot == -1 ) {
      return false;
      var strLength = inFileName.toString().length;
      var extension = inFileName.toString().substr( lastDot + 1, strLength - lastDot );
      extension = extension.toLowerCase();
      for (var i = 0; i < inArrayOfFileExtensions.length; i++ ) {
      if ( extension == inArrayOfFileExtensions[i] ) {
      return true;
      return false;
