4 Replies Latest reply on Nov 19, 2015 2:38 AM by Johnwhite
    InDesign Check Spelling
    Johnwhite Level 1
      Hi experts
      Is that possible to collect typos in a list will then a new file?
      My target is a one single file's spelling checking.
      I need the script to collect those typos will then save the typos in a new file.
      no matter java, or C++ to make a plugin.
      If you are have a good idea, please help me to finish it.
      I'll very happy to pay for this.
      Regard
      John
        • 1. Re: InDesign Check Spelling
          tpk1982 Level 4
          Hi John, Use the below script
          // Collect broken words and place them (sorted, duplicates removed, exception list filtered out) in a new document
          #target indesign;
          if (app.documents.length > 0)
              try {collect_broken_words ()}
                  catch (e) {alert (e.message + "\r(line " + e.line + ")")};
          function collect_broken_words ()
              var broken_words = find_broken_words (app.documents[0]);
              broken_words = check_exceptions (broken_words);
            var output = flow (broken_words.join ("\r"), 2);
          function check_exceptions (word_list)
              var pos;
              var word_list = del_duplicates (word_list);
              var lg = find_language ();
              lg = app.findKeyStrings (lg)[0].replace ("$ID/", "");
              var exceptions = app.userDictionaries.item (lg).addedWords;
              // create array (dashless) of words in the exception list with all swung dashes removed
              var dashless = exceptions.join ("£").replace (/~/g, "").split ("£");
              for (var i = word_list.length-1; i > -1; i--)
                  pos = binsearch (word_list[i].replace ("~", "").toLowerCase(), dashless);
                  if (pos > 0)
                      word_list.splice (i, 1);
              return word_list;
              function del_duplicates (array)
                  var str = array.sort (nocase).join ("\r") +"\r";
                  str = str.replace (/([^\r]+\r)(\1)+/g, "$1");
                  return str.replace (/\r$/,"").split ("\r");
              function nocase (a, b)
                  return a.toLowerCase () > b.toLowerCase ()
          function find_broken_words (doc)
              var broken = [];
              var fnotes, j;
              var stories = app.documents[0].stories.everyItem ().getElements ();
              for (var i = 0; i < stories.length; i++)
                  if (stories[i].lines.length > 1)
                      broken = find_broken (stories[i], broken);
                      fnotes = stories[i].footnotes.everyItem().getElements();
                      for (j = 0; j < fnotes.length; j++)
                          if (fnotes[j].lines.length > 1)
                              broken = find_broken (fnotes[j], broken);
              return broken
          function find_broken (obj, array)
              var part_1, part_2, w;
              var lines_ = obj.lines.everyItem().contents;
              var stop = lines_.length-1;
            var re1 = /^.+[\s\u002F\u2013\u2014]/;
            var re2 = /[\s\u002F\u2013\u2014].+$/;
            var re_del = /[.,;:«»†‡®©‹›\[\]\{\}!?()0-9\u2018\u2019\u201C\u201D\/\r\n]/g;
              for (var i = 0; i < stop; i++)
                  if (broken_line (lines_[i]))
                      part_1 = lines_[i].replace (re1, "");
                      part_2 = lines_[i+1].replace (re2, "");
                      w = part_1+"~"+part_2;
                      w = w.replace (re_del, "");
                      array.push (w)
              return array
          function broken_line (s)
              return "- \u2013\u2014\u00AD\r/".search (s.slice (-1)) < 0;
          // Write array in a new document (after sorting and deleting duplicates)
          function flow (s, col)
            var doc = app.documents.add();
            doc.viewPreferences.rulerOrigin = RulerOrigin.pageOrigin;
            var marg = doc.pages[0].marginPreferences;
            var gb = [marg.top, marg.left,
            app.documentPreferences.pageHeight - marg.bottom,
            app.documentPreferences.pageWidth - marg.right];
            doc.textFrames.add ({geometricBounds: gb, contents: s, textFramePreferences: {textColumnCount: col}});
            while (doc.pages[-1].textFrames[0].overflows)
            doc.pages.add().textFrames.add ({geometricBounds: gb, textFramePreferences: {textColumnCount: col}});
            doc.pages[-1].textFrames[0].previousTextFrame = doc.pages[-2].textFrames[0];
              return doc;
          function binsearch (srch, array)
              return binsearch_sub (srch, array, 0, array.length-1)
          function binsearch_sub (srch, array, first, last)
              var temp, middle;
              middle = Math.round ((first + last) / 2);
              if (first > last)
                  temp = -1;
              else
                  if (array[middle] == srch)
                      temp = middle;
                  else
                      if (array[middle] > srch)
                          temp = binsearch_sub (srch, array, first, middle-1);
                      else
                          temp = binsearch_sub (srch, array, middle+1, last);
              return temp
          // Find the applied language: if there's a selection, return the language of the applied paragraph style; otherwise if there's a document,
          // return the language of the default paragraph style; if that doesn't work, return the language of the application's default paragraph style.
          function find_language ()
              try {var lg = app.selection[0].appliedParagraphStyle.appliedLanguage.name}
              catch (_)
                  try {var lg = app.selection[0].parentStory.appliedLanguage.name}
                  catch (_)
                      try {var lg = app.documents[0].textDefaults.appliedParagraphStyle.appliedLanguage.name}
                      catch (_) {var lg = app.textDefaults.appliedParagraphStyle.appliedLanguage.name}
              return lg
          function get_time () {return new Date().getTime()}
          function time_diff (start) {return (new Date() - start) / 1000}
          • 2. Re: InDesign Check Spelling
            Johnwhite Level 1
            thank you guy, but not really work.
            thank you so much.
            Regard
            John
            • 3. Re: InDesign Check Spelling
              Pickory Level 3
              There is a commercial plugin that does this. MindSpell.
              Mindsteam Software - MindSpell
              P.
              • 4. Re: InDesign Check Spelling
                Johnwhite Level 1
                Thank you Pickory
                The plugin has too many language,
                What I need is the English American, and English British and use InDesign inner dictionary, not external dictionary.
                And I really need I have a right to add words to the dictionary.
                thank you so much
                Regard
                John
