• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Blend (replace spine)
New Here ,
Nov 19, 2015 Nov 19, 2015
Hi. I have created outlines from type (made it an object?) and would like to use the blend tool. When I select the blended object and the object I want replaced, the replace spine option is grayed. Is there something else I need to do to the letters to make this work, or will it work with letters at all. I can get it to work with shapes I've drawn but not with letters. Help would be greatly appreciated.
If you are wondering, I am trying to create a rhinestone template.
Views
16.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , May 18, 2016 May 18, 2016
Object > Compound path > Release.
Votes
Translate
Translate
Adobe
Community Expert ,
Jan 23, 2016 Jan 23, 2016
you need to select your Blended object and a path (just one path). This path will become the new "spine" of your Blended object.
can you post screen shots of what you have that is not working?
Votes
Translate
Translate
Report
Report
Participant ,
I figured out part of the problem: if you're using outlines from type, then probably some of your paths are compound paths. You can't do the Replace Spine thing with compound paths; they have to be just "paths" (as shown in the Appearance box). I ended up having to redraw the compound path. After I did that, the "Replace Spine" option reappeared.
There must be a better way to turn a compound path into a regular path than by redrawing it, but I don't know. (I just found some options in another forum, but I haven't tried them.)
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Participant ,
May 23, 2016 May 23, 2016
Thanks! I thought I had tried that at the time, but I just did an experiment and it worked, so I must have done something wrong.
Votes
Translate
Translate
Report
Report
New Here ,
May 05, 2017 May 05, 2017
I have tried but compound path is also grayed, it does not allow me to do any changes
Votes
Translate
Translate
Report
Report
Community Expert ,
Please create a new thread and post a screenshot of your object together with the (open) layers panel.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 08, 2019 Mar 08, 2019
Hey same problem here do you guys figure out how it works?
Votes
Translate
Translate
Report
Report
Community Expert ,
Please create a new thread and show screenshots.
Don't forget the layers panel in your screenshots.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 16, 2019 Jul 16, 2019
(with blended object): Object > Envelope Distort > Expand
Votes
Translate
Translate
Report
Report
New Here ,
Aug 02, 2019 Aug 02, 2019
thanks so much this rlly helped
Votes
Translate
Translate
Report
Report
New Here ,
Mar 13, 2020 Mar 13, 2020
This one helped me. Thank you
Votes
Translate
Translate
Report
Report
New Here ,
May 30, 2020 May 30, 2020
I realeased the compound path, then used Patherfinder-Merge to make them one shape. Replace spine worked, but it kind of outlines the letter in 3D. So kind of works, kind of not.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 05, 2021 Oct 05, 2021
LATEST
Thanks , it helped me .
Votes
Translate
Translate
Report
Report
