1 Reply Latest reply on Nov 24, 2015 10:14 AM by WCBaxter
    apple script help needed
    davidn5918184 Level 1
      In InDesign cc I have the "copy all link information" mapped to the keyboard shortcut shift+option+L. With a image selected, when the script is triggered it displays a dialogue box asking what needs to be done sets that to a variable, then runs the keystroke shift+option+L to copy the link info. Next it creates a text file on the desktop if its not there and appends it with the display box variable and pastes the link information. The problem is that it doesn't copy the link information correctly. Its as if its delayed. For example. If I copy something to the clipboard like the word "capture" and then select the image and run the script it will paste the word "capture" instead of the link information. But if I run it again on a different image it will paste the link information from the first time I ran the script. Its like its delayed by 1. Anyhow if anyone has any idea how to fix this strange behavior I would be grateful. Perhaps it would work with javascript, Im not sure.
      ~David
      --dialog box
      display dialog "What do you need done" default answer "Remove Background"
      set theAnswer to (text returned of result)
      activate application "Adobe InDesign CC 2015"
      tell application "System Events" to keystroke "L" using {shift down, option down}
      end
      set this_story to "
      ------------------- " & theAnswer & " -------------------
      set this_file to (((path to desktop folder) as string) & "ArtCorrections.txt")
      my write_to_file(this_story, this_file, false)
      on write_to_file(this_data, target_file, append_data)
        try
        set the target_file to the target_file as string
        set the open_target_file to open for access file target_file with write permission
        if append_data is true then set eof of the open_target_file to 0
        write this_data to the open_target_file starting at eof
        close access the open_target_file
        return true
        on error
        try
        close access file target_file
        end try
        return false
        end try
      end write_to_file
      set myVar to the clipboard
      my write_to_file(myVar, this_file, false)
      on write_clip_file(myVar, target_file, append_data)
        try
        write myVar to the open_target_file starting at eof
        return true
        on error
        try
        end try
        return false
        end try
      end write_clip_file
