1 Reply Latest reply on Nov 22, 2006 8:42 AM by clbeech
    Is it possible to change a scene to a slide?
    pandeli74
      Is it possible to change a flash document to a flash presentation, or a scene to e slide?
        • 1. Re: Is it possible to change a scene to a slide?
          clbeech Level 3
          Sure, although I don't think there is an automated way to that. Just select all frames, then use 'copy frames' in the original timeline, open a new document as in the Flash slide class, select the first frame and use 'paste frames'. All the original frames should now be on that particular slide level, it should also paste in the names of all of your original layers. It doesn't matter if they have animation, since the slide class supports it. But all of this depends on what your trying to bring into the slide. More info about what your document contains would be helpful?
