I'm making animated banners that loop 3 times from start to finish, the banner's contents alpha out on the ending frame, but on the third loop I would like the elements to stay visible and make the banner stop moving. How may I use Actionscript to accomplish this?
How do you control the alpha, via a timeline tween or a coded tween?
In any case you will need to start with having a loop counter so that you can tell when you have reached the desired end point 3 times. for that you could have something like the following in frame 1...
var count:Number;
if(isNaN(count)){
count = 0;
that will set the initial value of the count variable to zero but also keep the variable from resetting to 0 every time you return to that frame. Then in the frame where you desired to stop...
count += 1;
if(count == 3){
stop();
I control the alpha via a timeline tween.
Then either stop the third loop at the start of the tween before it fades, or if you want it to fade before stopping and then re-appear, place it at the end of the timeline and include a command to set the alpha back to 1 in the conditional.
