3 Replies Latest reply on Nov 19, 2015 7:03 PM by Chuck Uebele
    PS JS script aligning image to center, want to align to left.
    gingerj
      Hi there, i have a PS script that replaces an image layer in the PSD file with an external PNG file. and saves the newly created as a new PNG.
      Right now, the way it works, it aligns the image to the center in the bounds of the earlier image.
      What i would like is that it aligns it to the left in the bounds of the earlier image, instead of center aligning it.
      Here's the code that i'm using that I think center aligns to the bounds-
      [code]
      pasted_bounds=psdDoc.activeLayer.bounds;
      flag_width=Number(pasted_bounds[2]-pasted_bounds[0]);
      flag_height=Number(pasted_bounds[3]-pasted_bounds[1]);
      psdDoc.activeLayer.translate(original_bounds[0]-pasted_bounds[0]+((original_width-flag_wid th)/2),original_bounds[1]-pasted_bounds[1]+((original_height-flag_height)/2));
      [/code]
      Looking forward to the community. Thanks.
      Also, i miss PS-Scripts community and Mike
      Here's the complete code in case someone wants to look at it -
      PS it also replaces a text image using list1.txt, that's working fine and i didn't include code for it.
      [code]
      var working_directory="/C/work-files/";
      var image_txt="list2.txt";
      var display_name_txt="list1.txt";
      //----------------------------------COMMON HOUSEKEEPING---------------------------------------------------------
      var strtRulerUnits = app.preferences.rulerUnits;
      var strtTypeUnits = app.preferences.typeUnits;
      app.preferences.rulerUnits = Units.INCHES;
      app.preferences.typeUnits = TypeUnits.PIXELS;
      app.displayDialogs = DialogModes.NO;
      //-------------------------OPEN GUIDE PSD FILE----
      guide_file=new File(working_directory+"guide.psd");
      if (!guide_file.exists)  Window.alert("guide.psd not found in the working directory");
      open(guide_file);
      psdDoc=app.activeDocument;
      flagLayer=psdDoc.artLayers.getByName("ChangeMe2");
      shapeLayer=psdDoc.artLayers.getByName("Shape 1");
      flagLayer.moveAfter(shapeLayer);
      //flagLayer.move(shapeLayer,ElementPlacement.INSIDE);
      //Window.alert(psdDoc.artLayers.length);
      //Window.alert(shapeLayer.kind);
      for(i=0;i<psdDoc.artLayers.length;i++){
        psdDoc.artLayers[i].visible=false;
      flagLayer.visible=true;
      original_bounds=flagLayer.bounds;
      psdDoc.trim(TrimType.TRANSPARENT,true,true,true,true);
      original_width=Number(original_bounds[2]-original_bounds[0]);
      original_height=Number(original_bounds[3]-original_bounds[1]);
      original_resolution=Number(psdDoc.resolution);
      original_ar=original_width/original_height;
      psdDoc.close(SaveOptions.DONOTSAVECHANGES);
      //-------------------------CLOSE GUIDE PSD FILE-----------------------------------
      txtfile_text=new File(working_directory+display_name_txt);
      Window.alert(txtfile_text.open('r') ? "LIST1:OK" :"File Not Found:names list" );
      txtfile_image=new File(working_directory+image_txt);
      Window.alert(txtfile_image.open('r') ? "LIST2:OK" : "File Not Found: Image list");
      while( pic_file= txtfile_image.readln())
      flag_name= txtfile_text.readln();
      file2=new File(working_directory+pic_file);
      open(file2);
      var picDoc=app.documents.getByName(pic_file);
      app.activeDocument=picDoc;
      picDoc.trim(TrimType.TRANSPARENT,true,true,true,true);
      flag_bounds=picDoc.activeLayer.bounds;
      flag_width=Number(picDoc.width);
      flag_height=Number(picDoc.height);
      flag_ar=flag_width/flag_height;
      flag_resolution=Number(picDoc.resolution);
      diff_width=Math.abs(original_width*original_resolution-flag_width*flag_resolution);
      diff_height=Math.abs(original_height*original_resolution-flag_height*flag_resolution);
        picDoc.resizeImage( Number(flag_ar)*Number(original_height), original_height,original_resolution);
        }else{
        picDoc.resizeImage( original_width, (Number(original_width)/flag_ar),original_resolution);
      //picDoc.resizeImage(original_width,original_height,original_resolution);
      picDoc.selection.selectAll();
      picDoc.selection.copy();
      picDoc.close(SaveOptions.DONOTSAVECHANGES);
      //---------------------------OPEN GUIDE PSD FILE ----------------------
      open(new File(working_directory+"guide.psd"));
      psdDoc.activeLayer=flagLayer;
      psdDoc.selection.selectAll();
      psdDoc.selection.clear();
      psdDoc.selection.deselect();
      psdDoc.paste();
      //psdDoc.activeLayer.translate(original_bounds[0]-pasted_bounds[0],original_bounds[1]-past ed_bounds[1]);
      //permit vertical alignment
      //psdDoc.activeLayer.translate(0,original_bounds[1]-pasted_bounds[1]);//commented out on 1/14/2009 -ISSUE2
      [/code]
