0 Replies Latest reply on Nov 20, 2006 11:40 PM by damonevans2
    FLEX and nested repeaters
    damonevans2
      I’m having a problem with dynamically changing the dataProvidors of nested repeaters. Im getting unexpected results with repeated elements being positioned in the wrong places. Any help would be appreciated (Just a thought though… do you know if using a ‘repeat’ event to dynamically change the dataProvider of a nested repeater would get around the below problem?)
      This is the mxml code I’m using to repeat the UI components:-
      Now the above code should logically work, but I get this unexpected result:-
      The product number in green should be under ‘Base System’ and the block of product numbers in red should be under ‘Elite II…’ but the rest of the order is fine. Any other suggestions?
      Many Thanks
      Damon
