6 Replies Latest reply on Dec 1, 2015 7:30 AM by Russ Ward
    Working off paragraphs in two successive While loops
    K.Daube Level 1
      Dear experts,
      In continuation of "How to define the offset for a textrange (after a TAB)?" i have implemented the snippet into the existing script-flow (simplefied for the presentation here):
      • Read an RTF which contains two parts of tabbed paragraphs. See the file FM-biblio-collected-test.fm.
        This contains 4 paragraphs in the first part and 3 paragraphs in the second part.
      • Reading pgfs in the first part works perfectly. These all start with [[   (script lines 10 ... 26)
      • The first pgf of the second part (paragraph number 5) is already read, terminating the first While loop due to missing [[ at the beginning.
      • Further processing of this paragraph (script lines 27 ... 35) reveals that not paragraph 5, but paragraph 1 is processed! (textrange in line 41 is from position 21 to 22, which fits only to the first paragraph!
      • Of course this leads to the message in line 43
      Why does line 29 not get the same paragraph object (paragraph 5) as it was handled correctly in the previous While as last object?
      // Have the expanded RTF file (FM-biblio-collected-test.fm) open
      #target framemaker
      var goRtfDoc = app.ActiveDoc;
      var pgf = goRtfDoc.MainFlowInDoc.FirstTextFrameInFlow.FirstPgf;  // get first pgf in flow
      var TAB = String.fromCharCode(8);               // FM has wrong ASCI for TAB
      var tabRange
      // --- read the temp/formatted citations --- "formatted" consist of the reference number only
        while (pgf.ObjectValid()) {
          pgfText = GetText (pgf, goRtfDoc);
          if (pgfText.substring (0,2) === "[[") {       // citation lines start with [[
            parts = pgfText.split(TAB);                 // get the two parts of the line
            parts[0] = parts[0].replace("[[", "{");     // replace [[...]] by {...} for find in user doc
            parts[0] = parts[0].replace("]]", "}");
            if (parts[1].substring (0,1) === "{") {     // this placeholder is unresolved, skip it
              nUnres += 1;
              pgf = pgf.NextPgfInFlow;
              continue;
      //    gasFmtCitsRaw.push (parts[0]);              // store the placeholder citation
      //    gasFmtCitsFmt.push (parts[1]);              // store the formatted citation (just a number)
          } else { break }                              // first line of bibliography encountered
      // --- read the bibliography paragraphs
        while (pgf.ObjectValid()) {                     // until end of doc
          tabRange = GetTabRange (pgf, goRtfDoc);       // Get the text range starting after the TAB to the end of the paragraph.
      //  gaoBibliography.push(tabRange);               // store the paragraph-part in the array
          goRtfDoc.TextSelection = tabRange;      // for later use in tests
          goRtfDoc.Copy (0);                      // Check manually what can be copied
          alert ("are we OK?");
      function GetTabRange (pgf, doc) {
        var textLoc, textRange, findParams, tabRange;
        textLoc = new TextLoc (pgf, 0);                 // Make a text location at the beginning of the paragraph.
        findParams = GetFindParams ("\x08");            // Get the find parameters for finding a tab.
        textRange = doc.Find (textLoc, findParams);     // Search for the string.
        if (textRange.beg.obj.ObjectValid ()) {         // See if the tab was found.
          alert (textRange.beg.obj.Unique + "    " + pgf.Unique);   //?? Is <> if cursor is not at start of pgf.
          if (textRange.beg.obj.Unique === pgf.Unique) {// Make sure the tab is in the correct paragraph.
            // Select the text from after the tab up to the end of the paragraph.
            tabRange = new TextRange (new TextLoc (pgf, textRange.beg.offset+1), new TextLoc (pgf, Constants.FV_OBJ_END_OFFSET - 1));
            return tabRange;                            // Return the text range.
        return 0;                                       // TAB Not found
      function GetFindParams (string) {
        var findParams = AllocatePropVals (1);
        findParams[0].propIdent.num = Constants.FS_FindText;
        findParams[0].propVal.valType = Constants.FT_String;
        findParams[0].propVal.sval = string;
        return findParams;
      } // --- end of GetFindParams
      function GetText (textObj, doc) {
        var j, text = "", textItems;
        if (textObj.constructor.name !== "TextRange") { // Get a list of the strings in the text object or text range
          var textItems = textObj.GetText(Constants.FTI_String);
        } else {
          textItems = doc.GetTextForRange(textObj, Constants.FTI_String);
        for (var j = 0; j < textItems.len; j += 1) {    // Concatenate the strings
          text += (textItems[j].sdata);
        return text;                                    // Return the text
      } // --- end GetText
      Any ideas are welcome
      Klaus Daube
        • 1. Re: Working off paragraphs in two successive While loops
          K.Daube Level 1
          Further investigation with the test file mentioned in the first post.
          To come closer to the problem I insert logging (the Console command does not log into the JavaScript console of ESTK, hence the $.writeln)
          after line 41:    $.writeln ("3: "+ textRange.beg.obj.Unique + "    " + pgf.Unique);
          Line 43 removed.
          after line 27:    $.writeln ("2: " + pgf.Unique);
          after line 12:    $.writeln ("1: " + pgf.Unique);
          Then I put the cursor at the beginning of the the test file and run the script.
          The console shows this (<- ... is comment)
          1: 999540        <- first para in first part
          1: 999551        <- second para in first part
          1: 999562        <- third para in first part
          1: 999571        <- fourth para in first part
          1: 999582        <- fifth para =  first of second part
          2: 999582
          3: 999540    999582
          3: 999551    999593
          3: 999562    999606
          Result: [object Pgf]
          Hence GetTabRange searches in the first three pgfs of the document, although the While loop runs through the 3 pgf of the second part.
          Why this?
          • 2. Re: Working off paragraphs in two successive While loops
            K.Daube Level 1
            I'm still stuck in this problem:
            In fucntion GetTabRange (pgf, doc) the line
            finds the TAB in the first paragraph of the test document (red rectangle), not in the current paragraph (blue rectangle). The read lines to the right indicate the Para-IDs
            I have placed a breakpoint in function GetTabRange and tiptoed until after the Find:
            At this point the databrowser confirms with the values for the begin- and end-offsets that I'm in the first paragraph, not the fifth.
            Why does doc.find search not search in the current paragraph (ID = 999582)?
            • 3. Re: Working off paragraphs in two successive While loops
              Russ Ward Level 4
              Klaus,
              I can't explain the behavior you are seeing, as it appears that textLoc is ignored in line 41:
              I don't know if it is a bug, or what the problem is. However, I did find a potential workaround. I added the following lines just before line 41, in order to force the insertion point to the beginning of the current paragraph:
              var searchStart = new TextRange(new TextLoc(pgf,0), new TextLoc (pgf, 0));
              doc.TextSelection = searchStart;
              ...as in:
              var searchStart = new TextRange (new TextLoc (pgf,0), new TextLoc (pgf, 0));
              return tabRange;
              return 0;
              // TAB Not found
              After this, the behavior of the script seems to match what you want. I hope this helps some. By the way, the code sample looks all crazy in my browser editor, not sure how it will appear when I click Add Reply.
              Russ
              • 4. Re: Working off paragraphs in two successive While loops
                Russ Ward Level 4
                OK, it added lots of empty lines, but I think all the content is still there.
                • 5. Re: Working off paragraphs in two successive While loops
                  K.Daube Level 1
                  Thank You very much, Russ, this is really the solution to my problem.
                  And it's a relief that also the experts have no idee whythe waters are so murky.
                  Klaus
                  The correctly working function is this:
                  // --- the following two lines by Russ Ward  saved my project
                  // --- because otherwise the following statement starts at the beginning of the file, not the current pgf
                  • 6. Re: Working off paragraphs in two successive While loops
                    Russ Ward Level 4
                    Also, I apologize that my response was so delayed. I took a week off for the US Thanksgiving holiday and hardly touched the computer during that time. I'm thankful for that.
