3 Replies Latest reply on Nov 22, 2006 10:34 PM by Alok Jain
    Resizing Images
    Alok Jain
      How can i resize a dynamically loaded image in flash?
        • 1. Re: Resizing Images
          Yes, you can... but first you need to make sure that the image was loaded.
          so, on this.new_mc.getBytesLoaded() == this.new_mc.getBytesTotal() you can set the action.
          the code below works fine:
          this.createEmptyMovieClip("new_mc", this.getNextHighestDepth());
          _root.onEnterFrame = function()
          if(_root.new_mc.getBytesLoaded() == _root.new_mc.getBytesTotal() && _root.new_mc.getBytesLoaded() > 0)
          delete _root.onEnterFrame;
          _root.new_mc._xscale = _root.new_mc._yscale = 15;
          • 2. Re: Resizing Images
            Marghoob Suleman Level 1
            Hi There,
            Its better to use loadClip() rather than loadMovie().
            and you can set or get the height or width on onLoadInit.
            • 3. Re: Resizing Images
              Alok Jain Level 1
              Thanks for help
              with _xscale and _yscale i found that it makes problem when i am using different size of images. because it sets the size in percentage. I used height and width instead.
              Another problem i found is proportion of images. Here is the final code that resizes the images proportionately.
