3 Replies Latest reply on Nov 21, 2015 4:59 PM by A.T. Romano
    How do I turn of autoanalyzer in adobe premier elements 13? I can see it running in the task manager as elementsautoanalyzer13.exe but didn't want to end the process in case it affected the program.  There must be a way inside the adobe program to turn it
    rebeccah63905267
      How do I turn of autoanalyzer in adobe premier elements 13? I can see it running in the task manager as elementsautoanalyzer13.exe but didn't want to end the process in case it affected the program.  There must be a way inside the adobe program to turn it off because i turned it on by right clicking an image in the premiere editor and then when prompted it said it would run in the background and i said OK-now i cant stop it!!!! .  It seems in earlier versions of premiere elements under  Edit->Preferences->Media Analysis you could  uncheck everything to turn it off.  But there is only a Media section and in this tab there is no autoanalyzer to be seen.  Thanks in advance for any advice
