4 Replies Latest reply on Nov 20, 2006 10:12 PM by abeall
    ContextMenuItem
    abeall Level 3
      Wondering if anyone else gets the same results. Try this on a new document:
      var cm = new ContextMenu();
      cm.hideBuiltInItems();
      cm.customItems.push( new ContextMenuItem("Select",select,false,true,true) );
      cm.customItems.push( new ContextMenuItem("Rename",rename,false,true,true) );
      _root.menu = cm;
      function select(){}
      function rename(){}
      Publish, right click. Why doesn't "Select" appear in the menu? Now, rename "Select" to "Selects". Why does it appear now?
        • 1. Re: ContextMenuItem
          Level 7
          > _root.menu = cm;
          > function select(){}
          > function rename(){}
          "select" it's a reserved work and you can't use it.
          Try something else like "Select It"
          Best Regards
          Urami
          <urami>
          If you want to mail me - DO NOT LAUGH AT MY ADDRESS
          </urami>
          • 2. Re: ContextMenuItem
            Level 7
            work=word
            • 3. Re: ContextMenuItem
              Marghoob Suleman Level 1
              and even copy and paste words are also reserved.
              • 4. Re: ContextMenuItem
                abeall Level 3
                You can't even use a reserved word as a label? That doesn't totally make sense to me... phooie. Went with "Select objects" in this case.
                Thanks urami and Marghoob.
