2 Replies Latest reply on Jun 11, 2006 8:07 PM by Shigeru@Linkcom
    in 7.0.1, something crashes Session Scope.
    Shigeru@Linkcom Level 1
      Hi.
      We're groping in the dark.
      Our some clients update to 7.0.1. Then Exception happen sometimes, not 100%.
      (This exception had never happen before updating to 7.0.1.)
      Sometimes the variable that should be a structure has become it not a structure.
      Sometimes the variable that should be array has become it not a array.
      The variables are copied from Session Scope to Request Scope.
      It's becoming very serious problem.
      Anyone have same problem??
        • 1. Re: in 7.0.1, something crashes Session Scope.
          mike.short Level 1
          We are having the same problem, but only in one of our applications. It has a particularly large structure that loses integrity randomly, much as you describe. It is only marginally predictable where the problem will occur. We can't reproduce the problem, and have instead installed an error handler that traps the problem, and allows the visitor to reset the state.
          Removing the Duplicate function reduced, but did not eliminate the problem.
          • 2. Re: in 7.0.1, something crashes Session Scope.
            Hi, mike.short.
            Thank you for your information.
            I tried to make huge session scope, but this problem never happened.
            So I think a problem seems to be caused by another cause.
            We have several customers that have this problem.
            All of them have upgraded from MX 6.x to MX 7.0.1.
            What about your case?
