6 Replies Latest reply on Nov 25, 2015 2:16 PM by Jao vdL
    Disaster performance with lightroom 6.3
    nejcm96663459
      Hi!
      updated from 6.2 that was at least working, but slow. now it is unusable. it is eating memorry till the system pauses the application. currently 25gb memory used and 20 gb compressed memory, doing nothing!! (paused mobile sync, face detection, ....!!) and growing.
      i was unable to get system information without force closing lightroom and restarting... :/:/
      my system:
      Lightroom version: CC 2015.3 [ 1052427 ]
      License: Creative Cloud
      Operating system: Mac OS 10
      Version: 10.10 [5]
      Application architecture: x64
      Logical processor count: 8
      Processor speed: 2.5 GHz
      Built-in memory: 16,384.0 MB
      Real memory available to Lightroom: 16,384.0 MB
      Real memory used by Lightroom: 1,326.7 MB (8.0%)
      Virtual memory used by Lightroom: 2,782.0 MB
      Memory cache size: 157.6 MB
      Maximum thread count used by Camera Raw: 8
      Camera Raw SIMD optimization: SSE2,AVX,AVX2
      Displays: 1) 3840x2400
      Graphics Processor Info:
      NVIDIA GeForce GT 750M OpenGL Engine
      Check OpenGL support: Passed
      Vendor: NVIDIA Corporation
      Version: 4.1 NVIDIA-10.4.2 310.41.35f01
      Renderer: NVIDIA GeForce GT 750M OpenGL Engine
      LanguageVersion: 4.10
      Application folder: /Applications/Adobe Lightroom
      Library Path: /Users/nejcmenard/Pictures/Lightroom/Lightroom Catalog.lrcat
      Settings Folder: /Users/nejcmenard/Library/Application Support/Adobe/Lightroom
      Installed Plugins:
      1) Aperture/iPhoto Importer Plug-in
      2) Canon Tether Plugin
      3) Facebook
      4) Flickr
      5) Koken
      6) Leica Tether Plugin
      7) Nikon Tether Plugin
      Config.lua flags: None
      AudioDeviceIOBlockSize: 512
      AudioDeviceName: Built-in Output
      AudioDeviceNumberOfChannels: 2
      AudioDeviceSampleRate: 44100
      Build: Uninitialized
      CoreImage: true
      GL_ACCUM_ALPHA_BITS: 0
      GL_ACCUM_BLUE_BITS: 0
      GL_ACCUM_GREEN_BITS: 0
      GL_ACCUM_RED_BITS: 0
      GL_ALPHA_BITS: 8
      GL_BLUE_BITS: 8
      GL_DEPTH_BITS: 24
      GL_GREEN_BITS: 8
      GL_MAX_3D_TEXTURE_SIZE: 2048
      GL_MAX_TEXTURE_SIZE: 16384
      GL_MAX_TEXTURE_UNITS: 8
      GL_MAX_VIEWPORT_DIMS: 16384,16384
      GL_RED_BITS: 8
      GL_RENDERER: NVIDIA GeForce GT 750M OpenGL Engine
      GL_SHADING_LANGUAGE_VERSION: 1.20
      GL_STENCIL_BITS: 8
      GL_VENDOR: NVIDIA Corporation
      GL_VERSION: 2.1 NVIDIA-10.4.2 310.41.35f01
      GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
      Adobe, what is happening?
      any suggestions? system allready restarted, catalog optimised.
      thank you!
        • 1. Re: Disaster performance with lightroom 6.3
          Keith_Reeder Level 4
          The recurring theme in pretty much every single every post like this?
          Mac.
          Lr flies on my Win 8.1 box...
          But assuming you won't move to Windows, the standard advice is - roll back to the previous version.
          Roll back to a prior update version
          • 2. Re: Disaster performance with lightroom 6.3
            Jao vdL Adobe Community Professional & MVP
            I don't see this on my Mac. In fact 2015.3 seems to be faster than 2015.1.1. I can even turn on gpu acceleration now without major slowdowns even when using brushes. 2015.2 was completely unusable. Does this also happen with a fresh, empty catalog?
            • 3. Re: Disaster performance with lightroom 6.3
              sarsaxen Adobe Employee (Admin)
              Hi Nejcm,
              We are sorry to hear about the issue.
              Can you please try the following steps:
              Solution 1:
              • Go to Lightroom > Preferences(Mac) or Edit> Preferences(Windows)
              • Click on the Performance
              • Uncheck “Use Graphic Processor” and Restart Lightroom
              Solution 2:
              Reset Lightroom preferences by holding the  shift + option (Mac) or shift+alt (Windows) while launching Lightroom.
              Please let us know if it helps.
              Regards
              Sarika
              • 4. Re: Disaster performance with lightroom 6.3
                bhousto90 Level 4
                Can you please confirm by "memory" you mean Lightroom is consuming that much RAM? Because the numbers do not add
                up when you say it is using 25Gb +20Gb compressed. Your system info indicates that you only have a total of 16Gb RAM installed.
                So it sounds like you are actually telling us it is using a total of 45Gb of hard drive storage/space?
                In which case the solution we give to you will be entirely different.
                If indeed it is actually a HD storage problem how much free space does your hard drive currently have and how big is your catalog?
                I suspect LR is busy creating previews for your catalog and your Camera RAW cache size may be too big for the available space you have.
                You may also have a video cache that ran oversize (A problem that was present for some people when using LR6.2) that you may be able to delete.
                • 5. Re: Disaster performance with lightroom 6.3
                  nejcm96663459 Level 1
                  Hi!
                  well, also having problems offloading 16gb card with cca.400 photos (card is formated with no errors what so ever) third time succesfully. yes, the amount of ram my machine has is 16gb. the ram consumed was read from the activity monitor, tab memory (osX)...
                  40+gb disk free...
                  raw cache setting and video cache limit both at 3gb....
                  thank you all for responses! i hope i find a working solution.
                  • 6. Re: Disaster performance with lightroom 6.3
                    nejcm, one thing that will bring Lightroom completely to its knees if you import more than a few images at a time is to have automatic face detection turned on. Make sure that in catalog settings->Metadata you have it turned off. Double check using the little triangle next to the logo in the upper left corner that it is paused. It will balloon your memory usage and make the entire Lightroom experience unbearably slow. It's really quite bad to have it turned on. Secondly, except if you have the very best very latest Mac Pro, keep GPU acceleration turned off in Preferences->Performance. Having it turned on will significantly slow down your Lightroom workflow.
