1 Reply Latest reply on Nov 22, 2006 3:15 AM by Devendran
    accessing loader's content using XML
    Sixfoot James
      I've loaded an image into a loader from an XML file. Now I need to access that image to change it's X position. How do I go about doing this?
      I have used the debug to list all my objects, but my image is going to change whenever it loads a new one, so I can't use the image name...
      The array which holds my images is called propertyImage and I would have thought I could do this:
      _root.loader_mc.propertyImage[currentProperty]._x
      but that didn't work
      I've also tried this but it didn't work either:
      _root.loader_mc.content._x
      Thanks...
        • 1. Re: accessing loader's content using XML
          Devendran Level 1
          LoadMovie, LoadVars, Load, Functions are independent functions. We can't expect the Result immediately. It will take its own time to load(According to the file size and System config). So u have to use Any listener to Listen the Loading process. Better to move with LoadClip class. See the help on flash help files.
