8 Replies Latest reply on Dec 5, 2015 3:50 PM by sbimdesign
    After Effects can't Continue - 0 :: 42
    shubhamc Level 1
      After Effects was working fine and now suddenly I have this error 0 ::42
      "After Effects can't continue:sorry After Effects has crashed ..... 0 ::42"
      I have searched around and could not find any solution to this.
      I am using Windows 10 and recently installed Creative Cloud. After the error I removed and reinstalled the After Effects. So the version I have is the 2015 - 13.5.1
      I would appreciate any help to resolve this issue.
        • 1. Re: After Effects can't Continue - 0 :: 42
          shubhamc Level 1
          additional feedback: I have now uninstalled Media Encoder and QuickTime and restarted the system, but still no change. Still getting 0::42 error at the start of After Effects/
          • 2. Re: After Effects can't Continue - 0 :: 42
            Nobody can tell you anything without exact system info or other technical details like the crash logs.
            Working with your Operating System’s Tools | Mylenium's Error Code Database
            Mylenium
            • 3. Re: After Effects can't Continue - 0 :: 42
              shubhamc Level 1
              Thanks Mylenium for your response. Here is my crash report:
              Faulting application name: AfterFX.exe, version: 13.5.1.48, time stamp: 0x55adf822
              Faulting module name: MSVCR120.dll, version: 12.0.21005.1, time stamp: 0x524f83ff
              Exception code: 0xc0000005
              Fault offset: 0x000000000003c616
              Faulting process id: 0x2bf4
              Faulting application start time: 0x01d1265696bf3e08
              Faulting application path: C:\Program Files\Adobe\Adobe After Effects CC 2015\Support Files\AfterFX.exe
              Faulting module path: C:\Program Files\Adobe\Adobe After Effects CC 2015\Support Files\MSVCR120.dll
              Report Id: e7f7b135-90e6-4e55-8482-7ba3de7fbc3c
              Faulting package full name:
              Faulting package-relative application ID:
              Here is my System Information:
              OS Name    Microsoft Windows 10 Home
              Version    10.0.10240 Build 10240
              Other OS Description     Not Available
              OS Manufacturer    Microsoft Corporation
              System Name    HOME
              System Manufacturer    ASUSTeK COMPUTER INC.
              System Model    N56JR
              System Type    x64-based PC
              System SKU    ASUS-NotebookSKU
              Processor    Intel(R) Core(TM) i7-4700HQ CPU @ 2.40GHz, 2394 Mhz, 4 Core(s), 8 Logical Processor(s)
              BIOS Version/Date    American Megatrends Inc. N56JR.204, 10/31/2013
              SMBIOS Version    2.7
              Embedded Controller Version    255.255
              BIOS Mode    UEFI
              BaseBoard Manufacturer    ASUSTeK COMPUTER INC.
              BaseBoard Model    Not Available
              BaseBoard Name    Base Board
              Platform Role    Mobile
              Secure Boot State    On
              PCR7 Configuration    Binding Not Possible
              Windows Directory    C:\WINDOWS
              System Directory    C:\WINDOWS\system32
              Boot Device    \Device\HarddiskVolume1
              Locale    United States
              Hardware Abstraction Layer    Version = "10.0.10240.16392"
              User Name    Home\HOME-PC
              Time Zone    Mountain Standard Time
              Installed Physical Memory (RAM)    12.0 GB
              Total Physical Memory    11.9 GB
              Available Physical Memory    8.18 GB
              Total Virtual Memory    13.7 GB
              Available Virtual Memory    9.88 GB
              Page File Space    1.81 GB
              Page File    C:\pagefile.sys
              Hyper-V - VM Monitor Mode Extensions    Yes
              Hyper-V - Second Level Address Translation Extensions    Yes
              Hyper-V - Virtualization Enabled in Firmware    Yes
              Hyper-V - Data Execution Protection    Yes
              • 4. Re: After Effects can't Continue - 0 :: 42
                sbimdesign Level 1
                Same issue here. AE stops with error 0::42.
                • 5. Re: After Effects can't Continue - 0 :: 42
                  Do your crash logs also indicate an issue with  MSVCR120.dll? Are you running the same OS as the original poster?
                  If so, you can try reinstalling the Visual C++ Redistributable Packages for Visual Studio 2013 from Microsoft. That fixes it for some.
                  Or you can try installing older versions of your software too. I recall some folks on the forum installed CC 2014 products and it fixed this error for them in CC 2015 (likely because installing it fixed the .dll file that had the issue).
                  Or you can try uninstalling your Adobe stuff, running the CC Cleaner, and then reinstalling.
                  • 6. Re: After Effects can't Continue - 0 :: 42
                    sbimdesign Level 1
                    No, it´s the PlugPlug.dll
                    Name der fehlerhaften Anwendung: AfterFX.exe, Version: 13.6.0.165, Zeitstempel: 0x5653196c
                    Name des fehlerhaften Moduls: PlugPlug.dll, Version: 6.1.0.158, Zeitstempel: 0x564a2e09
                    Ausnahmecode: 0xc0000005
                    Fehleroffset: 0x000000000014fb4f
                    ID des fehlerhaften Prozesses: 0xea8
                    Startzeit der fehlerhaften Anwendung: 0x01d12eb1a6dbd75b
                    Pfad der fehlerhaften Anwendung: C:\Program Files\Adobe\Adobe After Effects CC 2015\Support Files\AfterFX.exe
                    Pfad des fehlerhaften Moduls: C:\Program Files\Adobe\Adobe After Effects CC 2015\Support Files\PlugPlug.dll
                    Berichtskennung: 74927892-82e4-46e4-876d-c3bfa907a9b6
                    Vollständiger Name des fehlerhaften Pakets:
                    Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
                    System Windows 10 Pro 1511 Build 10586.17
                    • 7. Re: After Effects can't Continue - 0 :: 42
                      Okay. Still do what I suggested.
                      • 8. Re: After Effects can't Continue - 0 :: 42
                        sbimdesign Level 1
                        tried it - no success.
                        This is the error code:
                        Here is a error log from AdobeIPCBroker.log
                        2015-12-05 03:02:58:710 : ERROR vcfoundation::io::VCEndOfFile: WriteFile
                        race:    1 0X010B28CE
                           2 0X010AB101
                           3 0X010B3C2C
                           4 0X010B22BD
                           5 0X010B17E0
                           6 0X010AA76B
                           7 0X010B6AF7
                           8 0X010B6C1F
                           9 0X760238F4
                          10 0X772A5663
                          11 0X772A562E
