4 Replies Latest reply on Nov 29, 2015 9:55 PM by ashishd64352316
    Ashish Dewan - advice needed for Flash Player
    ashishd64352316
      Hi everybody, here is Ashish Dewan. I am a new member of this online discussion board. I am facing problems related to adobe flash player. Whenever I am trying to watch any video on YouTube or any other video site, I am unable to watch the video due to adobe flash crashed. I have uninstalled it 3 times and installed again but it is not working again and again. I am using Window 7 Operating system. Could you please help me to get rid of this problem. I am looking forward for your responses.
      Ashish Dewan
        • 1. Re: Ashish Dewan - advice needed for Flash Player
          Carm01 Level 4
          What web browser are you referring to; Firefox perhaps?
          • 2. Re: Ashish Dewan - advice needed for Flash Player
            ashishd64352316 Level 1
            Hello Carm, thanks for your response. I use Mozilla Firefox. I always prefer Firefox..
            Ashish Dewan
            • 3. Re: Ashish Dewan - advice needed for Flash Player
              Carm01 Level 4
              OK, so this has been a problem that only exists in Firefox most notably since the implementation of plugin-container.exe
              This is 100% Firefox issue. I have found a partial solution that should help you out; hopefully.
              I stumbled across this and it has worked 99% of the time to stop plugin crashes ( actually plugin-container.exe crashes but thinks that the plugin has crashed )
              I hope you know how to make a BAT file? You can try this out on your system to see if it helps and if it does I will provide a link to a exe that sits in the system tray. ( Run one of these before you launch Firefox
              Here is the BAT file code below. Try this first. it just runs in a loop, and you can minimize it to see if it helps.
              You also might want to do a clean install. I simplified that process down to a script as well. You can browse either BAT version or exe here: Adobe Flash Updater - Browse Files at SourceForge.net
              @echo off
              :start
              del C:\Windows\Prefetch\PLUGIN-CONTAINER*.pf >nul 2>&1
              :: remove the >nul 2>&1 if you do not want to see messages like files does not exist for example
              del C:\Windows\Prefetch\flashpl*.pf >nul 2>&1
              del C:\Windows\Prefetch\firefox*.pf >nul 2>&1
              del C:\Windows\Prefetch\PLUGIN-HANG*.pf >nul 2>&1
              del C:\Windows\Prefetch\AGCP*.pf >nul 2>&1
              timeout 30
              goto :start
              Hopefully something I provided helps
              Best Regards
              • 4. Re: Ashish Dewan - advice needed for Flash Player
                Your reply is really helpful for me. When I use Google Chrome, the browser doesn't crash but Firefox is my preference and this the reasong why I am asking for help. I will try the process told by you and if I success to solve my problem thorugh your codes, I will save for future. Thanks for your kind support. I really appreciate you.
                Regards
                Ashish Dewan
