I would like to convert psd files into pdf files with editable text of the current photoshop levels. After i'll convert psd into pdf i should be able to open pdf file with adobe reader and edit the text .
If someone can help me i would be really glad cause its really important to me can figured it out.
Thank you so much!!
Gaia
Hi gaiar402796,
All the edits will be possible using Acrobat application.
Using Reader you won't be able to make any edits.
Regards,
Aadesh
Hi gaiar402796,
.psd is a supported file format for creating pdf Supported file formats | Acrobat, Reader.
You can use Acrobat DC to Create the PDF from .psd file https://helpx.adobe.com/acrobat/using/creating-simple-pdfs-acrobat.html.
Regards,
Aadesh
Thank you so much for your reply, and creating pdf file from psd file with acrobat DC, in the final pdf file will be editable the text just with adobe reader?
Thank you!
Regard,
Gaia
Hi gaiar402796,
Regards,
Aadesh
