3 Replies Latest reply on Nov 26, 2015 5:57 AM by Robin Driessen
    Indesign CC 2015 doesn't understand "place" applescript error -1708
    Robin Driessen
      If you could help me to solve my problem, that would be very kind! Thank you very much in advance.
      My script (yes, an old Indesign CS3-one that still worked well in CS5):
      tell application "Adobe InDesign CC 2015"
        activate -- switch naar indesign
        -- display dialog "..."
        -- creëer de dialoogbox voor invoer
        set myDialog to make dialog
        tell myDialog
        set name to "CTP Plaatsing Enve"
        set myDialogColumn to make dialog column
        tell myDialogColumn
        set myBorderPanel to make border panel
        tell myBorderPanel
        tell myDialogColumn
        -- make static text with properties {static label:"Ordernummer:"}
        set ingevoerd_ordernummer to make text editbox with properties {edit contents:"Werkordernummer", min width:150}
        end tell
        end tell
        tell myBorderPanel
        --make static text with properties {static label:"Machine:"}
        set drukpersen to make dropdown with properties {string list:{"HA3I", "HA6I", "HA4K", "571", "H3", "H6", "WenD", "522"}, selected index:0}
        end tell
        tell myBorderPanel
        --make static text with properties {static label:"Opmaak roteren:"}
        set opmaakroteren to make dropdown with properties {string list:{"Opmaak niet roteren", "90° met de klok mee", "90° tegen de klok in"}, selected index:0}
        end tell
        tell myBorderPanel
        --make static text with properties {static label:"Weerdruk:"}
        set schoonweer to make dropdown with properties {string list:{"Geen weerdruk", "Weerdruk", "Weerdruk op tweede plaat"}, selected index:0}
        end tell
        end tell
        show
        end tell
        set ordernummer to edit contents of ingevoerd_ordernummer
        -- bepaal machine met bijbehorende variabelen
        if selected index of drukpersen = 0 then -- HA3I
        set plaatbreedte to 311
        set plaathoogte to 251
        set plaatformaat_correctie to 0
        set drukaanvang to 30
        set weerdrukafstand to 120
        set machinelabel to "xHA3I"
        set pagina_orientatie to landscape
        else if selected index of drukpersen = 1 then -- HA6I
        set plaatbreedte to 387
        set plaathoogte to 494
        set weerdrukafstand to 240
        set machinelabel to "xH6br"
        set pagina_orientatie to portrait
        else if selected index of drukpersen = 2 then -- HA4K
        set plaatbreedte to 400
        set drukaanvang to 12
        set weerdrukafstand to 0
        set machinelabel to "xHA4K"
        else if selected index of drukpersen = 3 then -- 571
        set machinelabel to "x571"
        else if selected index of drukpersen = 4 then -- H3
        set machinelabel to "xH3"
        else if selected index of drukpersen = 5 then -- H6
        set weerdrukafstand to 241
        set machinelabel to "xH6"
        else if selected index of drukpersen = 6 then -- WenD
        set plaatbreedte to 420
        set plaathoogte to 491
        set drukaanvang to 42
        set machinelabel to "xWenD"
        else if selected index of drukpersen = 7 then -- 522
        set machinelabel to "x522"
        end if
        -- opmaak roteren
        if selected index of opmaakroteren = 0 then -- opmaak niet roteren
        set graden to 0
        else if selected index of opmaakroteren = 1 then -- opmaak met de klok mee roteren
        set graden to -90
        else if selected index of opmaakroteren = 2 then -- opmaak tegen de klok in roteren
        set graden to 90
        end if
        -- schoon/weer
        set aantal_paginas to pages per document of document preferences of active document
        if selected index of schoonweer = 0 then
        set weerdruk to 0
        set aantal_loops to aantal_paginas
        else if selected index of schoonweer = 1 then
        set weerdruk to 1
        set aantal_loops to (aantal_paginas / 2) as integer
        set aantal_paginas to (aantal_paginas / 2) as integer
        else if selected index of schoonweer = 2 then
        set weerdruk to 2
        end if
        -- verwijder nu de dialoogbox uit het geheugen
        destroy myDialog
        -- display dialog aantal_paginas
        -- initieer de rest van de variabelen
        set snijteken_offset to 8.2915 -- zie de CTP : verschuiving is 3 mm
        set ordernummer_regel to "Werkorder: " & ordernummer
        set geexporteerde_pdf_bestandsnaam to "ssd:Users:enve2:Desktop:CTP:" & ordernummer & machinelabel & ".pdf"
        set ctp_document_bestandsnaam to "ssd:Users:enve2:Desktop:CTP:" & ordernummer & machinelabel & ".indd"
        set registratiekleur to "Registration"
        set zwart to "Black"
        set wit to "White"
        -- exporteer de pdf die in het plaat-stramien geplaatst gaat worden
        -- let op! er wordt geen controle uitgevoerd!
        -- bijvoorbeeld: de 'koppelingen' worden niet gecontroleerd!
        tell active document
        export format PDF type to geexporteerde_pdf_bestandsnaam using "CTP" without showing options
        end tell
        -- maak een nieuw indesign document met de gewenste plaatafmetingen en het juiste aantal pagina's
        set ctp_document to make document
        set transform reference point of active window to center anchor
        set horizontal measurement units of view preferences to millimeters
        set vertical measurement units of view preferences to millimeters
        set PDF crop of PDF place preferences to crop PDF -- hoe wordt de pdf geplaatst ; in dit geval 'bijsnijden'
        set transparent background of PDF place preferences to true
        tell document preferences of ctp_document
        set facing pages to 0
        set page height to plaatbreedte -- height=breedte lijkt raar; maar anders werkt page orientation niet :-)
        set page width to plaathoogte -- idem
        set page orientation to pagina_orientatie
        set pages per document to aantal_paginas
        end tell
        tell margin preferences of ctp_document
        set column count to 1
        set top to 0
        set bottom to 0
        set left to 0
        set right to 0
        end tell
        tell text defaults of active document
        set fill color to registratiekleur
        set fill tint to 100
        set point size to "8pt"
        end tell
        set pdf_pagina to 1
        set ctp_pagina to 1
        repeat with teller from 1 to aantal_loops
        set page number of PDF place preferences to pdf_pagina as number -- selecteer de pdf pagina die geplaatst dient te worden
        tell page ctp_pagina of ctp_document
        set illustratiekader to make rectangle with properties {geometric bounds:{0, 0, plaathoogte, plaatbreedte}} -- maak illustratiekader
        set geplaatste_pdf_pagina to place geexporteerde_pdf_bestandsnaam on illustratiekader -- plaats de pdf pagina IN het illustratiekader
        set {dummy1, dummy2, pdfhoogte, pdfbreedte} to geometric bounds of geplaatste_pdf_pagina -- vraag de afmetingen van de pdf op
        «event InESkdrt» geplaatste_pdf_pagina given «class by  »:graden -- roteer eventueel de pdf in het illustratiekader (dus niet het illustratiekader zelf)
        if graden = 0 then -- pdf is niet geroteerd
        set movex to ((plaatbreedte - plaatformaat_correctie) / 2) - (pdfbreedte / 2) as number -- bereken de horizontale verplaatsing
        set movey to (plaathoogte - pdfhoogte - drukaanvang + snijteken_offset) as number -- bereken de verticale verplaatsing
        else if graden = -90 then -- pdf is geroteerd; met de klok mee
        set movex to ((plaatbreedte - plaatformaat_correctie) / 2) + (pdfhoogte / 2) as number -- bereken de horizontale verplaatsing
        set movey to {plaathoogte - pdfbreedte - drukaanvang + snijteken_offset} as number -- bereken de verticale verplaatsing
        else if graden = 90 then -- pdf is geroteerd; tegen de klok in
        set movex to ((plaatbreedte / 2) - (pdfhoogte / 2) - plaatformaat_correctie) as number -- bereken de horizontale verplaatsing
        set movey to {plaathoogte - drukaanvang + snijteken_offset} as number -- bereken de verticale verplaatsing
        end if
        move geplaatste_pdf_pagina to {movex, movey} -- voer de verplaatsing uit
        if machinelabel = "xHA4K" and graden = 0 then
        «event InESkdrt» geplaatste_pdf_pagina given «class by  »:180
        end if
        if machinelabel = "xWenD" and graden = 0 then
        end if
        if machinelabel = "x522" and graden = 0 then
        end if
        end tell
        if weerdruk = 1 then
        set pdf_pagina to pdf_pagina + 1
        set page number of PDF place preferences to pdf_pagina as number -- selecteer de pdf pagina die als weerdruk geplaatst dient te worden
        set movey to {plaathoogte - pdfhoogte - drukaanvang - weerdrukafstand + snijteken_offset} as number -- bereken de verticale verplaatsing
        set movey to {plaathoogte - pdfbreedte - drukaanvang - weerdrukafstand + snijteken_offset} as number -- bereken de verticale verplaatsing
        set movey to {plaathoogte - drukaanvang - weerdrukafstand + snijteken_offset} as number -- bereken de verticale verplaatsing
        end if
        if graden = 0 then
        flip item geplaatste_pdf_pagina given «constant flpohorz»
        else
        flip item geplaatste_pdf_pagina given «constant flpovert»
        end if
        end tell
        end if
        if weerdruk = 2 then
        set ctp_pagina to ctp_pagina + 1
        set movey to {plaathoogte - pdfhoogte - drukaanvang + snijteken_offset} as number -- bereken de verticale verplaatsing
        end if
        if graden = 0 then
        else
        end if
        end tell
        end if
        end repeat
        repeat with ctp_pagina from 1 to aantal_paginas
        tell page ctp_pagina of ctp_document -- maak hulplijnen
        make guide with properties {orientationconstant flpovert», locationplaatbreedte - plaatformaat_correctie) / 2} -- verticaal midden van de (evt. gesneden) plaat
        make guide with properties {orientationconstant flpovert», locationplaatbreedte / 2)} -- verticaal midden van het bestand
        make guide with properties {orientationconstant flpohorz», location:plaathoogte - drukaanvang}
        make guide with properties {orientationconstant flpohorz», location:plaathoogte - drukaanvang - weerdrukafstand}
        end tell
        end repeat
        -- sla het indesign document  met geplaatste pdf op
        tell active document to save to ctp_document_bestandsnaam
      end tell
        activate
        tell text defaults
        set fill color to zwart
        end tell
      end tell
