3 Replies Latest reply on Dec 3, 2015 2:04 AM by steverocket2
    compare two xml attribute values and get their parent element
    aviR Level 1
      Hello All
      I m stuck at a place.
      I am getting the values of two xml element attributes using two separate functions. I want to compare these values and if they are equal i want to insert a textframe in it's first insertion point.
      My code:
      function Flow(){
        var myRuleSet = new Array (new flow1);
        with(myDoc){
        var elements = xmlElements;
        __processRuleSet(elements.item(0), myRuleSet);
      function flow1(){
          this.name = "flow1";
          this.xpath = "//xref";
          this.apply = function(myElement,myRuleProcessor)
                     __processChildren(myRuleProcessor);
                     app.select(myElement);
                     xref_att = myElement.xmlAttributes.item("rid").value;
      function flow2(){
            this.name="fig";
            this.xpath="//fig";
            this.apply=function(elm,ruleproc)
                  __processChildren(ruleproc);
                 app.select(elm);
                  figele=elm.xmlattributes.item("id").value;
      My requirement is:
      if xref_att =figele, i have to insert textframe at the first insertionpoint of the element.
      How can i do that?
      Please help.
      Thank You
        • 1. Re: compare two xml attribute values and get their parent element
          Loic.Aigon Adobe Community Professional
          Not sure I got it all but here is an attempt:
          var main = function(){
            var doc, xes, n, xf = File ( Folder.temp+"/tmp.xml"),
            xo, nodes, found = [], xrefs, processed = {}, nid;
            if ( !app.documents.length) return;
            doc = app.activeDocument;
            //Passing through a xml file
            //to instantiate xml object
            //and avoid dealing with indesign xmlElements as much as possible
            doc.exportFile ( ExportFormat.XML, xf );
            xf.open("r");
            xo = XML( xf.read() );
            xf.close();
            //looking at fig nodes within the xml
            nodes = xo..fig.(@id!="");
            n = nodes.length();
            //if no fig nodes found return
            if ( !n) return;
            //otherwise we look at any xref tags with similar value
            while ( n-- ) {
            nid = String(nodes[n].@id);
            if ( !processed[nid] ){
            processed[nid] = true;
            xrefs = xo..xref.(@id==nid);
            xrefs.length() && found[ found.length ] = nid;
            //Getting every matches
            n = found.length;
            //If compliant nodes found
            //we loop through matches to add frames
            if (n>0){
            while ( n--){
            xes = doc.xmlElements[0].evaluateXPathExpression("//xref[@id='"+found[n]+"']");
            xes.length && addFrame( xes );
            //removing unwanted file
            xf.remove();
          function addFrame(xes){
            var n = xes.length;
            while ( n-- ) {
            var tf = app.activeDocument.textFrames.add();
            tf.anchoredObjectSettings.insertAnchoredObject(xes[n].texts[0].insertionPoints[0]);
            tf.anchoredObjectSettings.anchoredPosition = AnchorPosition.INLINE_POSITION;
          main();
          HTH
          Loic
          www.ozalto.com
          • 2. Re: compare two xml attribute values and get their parent element
            aviR Level 1
            I am trying this...
            function flow1(){
                       bMatch= false;
                       var xAtt1=myElement.xmlAttributes.item(0);
                       if(xAtt1.value=="fig"){
                         flow2(myElement,xref_att);
            function flow2(myElement,xref_att){
                 this.name="fig";
                 this.xpath="//fig";
                      app.select(elm);
                       if(xref_att ==figele){
                             var ins=myElement.insertionPoints[0] ;
                             var tf=ins.textFrames.add();
            It is getting the respective "xref" tag but then it is stopping the execution. It's not going further into the second function. Where am I wrong?
            Please help
            Thank You
            • 3. Re: compare two xml attribute values and get their parent element
              steverocket2 Level 1
              Your ruleSet is using only the first function:
              Try
                        new flow1,
                        new flow 2
