3 Replies Latest reply on Jul 26, 2016 4:06 AM by _Waylander_
    Convert swf to avi
    polinagu
      Hi everybody,
      I really need to export my flash file in avi format
      I can't see it in export options
      Please tell me how can i solve this problem
      Thank you
        • 1. Re: Convert swf to avi
          _Waylander_ Level 2
          You will have to Choose, Export as Movie, and export it as an MOV file. This will create a very large Raw Format of an MOV, as there are no compression settings, except the Resolution size.  So I would advise you insure you have enough space on your hard drive, for Gigabits of a file. Average can be 16 gigs for just a few minutes.
          After which if it does not already pop open, the media encoder will open from there I would create a good format MP4 and at the same time your AVI version.
          Once you have a nice clean MP4, I would delete the .mov file, And use the MP4 for any further conversions. Unless you have bags of room for files of great magnitude.
          • 2. Re: Convert swf to avi
            Colin Holgate MVP & Adobe Community Professional
            The Export as Movie you describe is how it would be in old versions of Flash Pro. More recent versions have an Export Video option.
            But, that's for exporting an FLA. If you have Premiere or After Effects you should be able to import the SWF there, and export video.
            • 3. Re: Convert swf to avi
              _Waylander_ Level 2
              Colin is right, my bad, I was writing without looking the option to export to MOV is :
              File ---> Export ---> Export Video
              And yes, if you have Premier or After Effects you could import the published swf, and even edit the animation again, add effects and music before exporting it to a file type of your needs.
