2 Replies Latest reply on Nov 20, 2006 7:58 AM by Cetrez
    Using variables in paths to objects
    Cetrez Level 1
      Hi
      I'm wondering how I can use a string in a declared variable for a path to an object. Here's an example:
      On the press of a button a variable is declared:
      _root.nextsection = "news";
      And later on I want to use the string "news" in a path, like this (on a frame action):
      if (_root.nextsection == "news") {
      this.nextsection.gotoAndPlay(1);
      As you can see in the second line I'm using the variable name as a path... but this doesn't work.
      Any suggestions?
        • 1. Re: Using variables in paths to objects
          Level 7
          Depending of where your if statement is, if your this.nextsection is the
          same as _root.nextsection, since this is a string and not an mc, what it
          does is:
          "news".gotoAndPlay(1).
          If you had a movieclip named news in the _root, then you could do:
          _root[_root.nextsection].gotoAndPlay(1) // EQUIVALENT TO _root["news"] or
          _root.news
          Other option is:
          var mynextsection_mc = eval("_root." + _root.nextsection) ;
          mynextsection_mc.gotoAndPlay(1);
          Flash will evaluate your constructed string "_root.news" to an object and
          return it, if it doesn't match anything, then you will get an undefined.
          JG
          "Cetrez" <webforumsuser@macromedia.com> wrote in message
          news:ejqacs$q6r$1@forums.macromedia.com...
          > Hi
          > an
          > frame
          > action):
          > but
          > this doesn't work.
          > Any suggestions?
          > Thanks
          • 2. Re: Using variables in paths to objects
            Cetrez Level 1
            Ok, I got it. :)
