While trying to do a fresh download & install of Illustrator CC 2015 I get an error (Failed to Download).
When I check for the details of the Download I see that the Exit Code is 126:
Exit Code: 126
-------------------------------------- Summary --------------------------------------
- 2 fatal error(s), 0 error(s), 2 warnings(s)
FATAL: Fatal Error '126' occurred while download
FATAL: Error occurred in download of package (Name: AdobeIllustrator19-Core Version: 19.1.0.29). Error code: '126'
WARN: Invalid arguments to utilDecodeBase64Data.
I am using the Adobe Application Manager (in OSX Yosemite).
Other application downloads (such as Photoshop and InDesign) have succeed, only Illustrator failed.
See screen capture:
Any hint will be appreciated.
you can try using different (wired) connection or download from prodesigntools.com by following the recommended steps.
if you follow all 7 steps you can directly download a trial here: Adobe CC 2015 Direct Download Links: Creative Cloud 2015 Release | ProDesignTools
if you have a problem starting the download, you didn't follow all 7 steps, or your browser does not accept cookies.
the most common problem is caused by failing to meticulously follow steps 1,2 and/or 3 (which adds a cookie to your
...Copy link to clipboard
the most common problem is caused by failing to meticulously follow steps 1,2 and/or 3 (which adds a cookie to your system enabling you to download the correct version from adobe.com).
failure to obtain that cookie results in an error page being displayed after clicking a link on prodesigntools.com or initiates the download of an incorrect (eg, current) version.
Thanks kglad, it worked like a charm.
You rock, my friend!
I tried the link and got an error message:
You don't have permission to access "http://trials3.adobe.com/AdobeProducts/ILST/19/osx10-64/Illustrator_19_LS20.dmg?" on this server.
Reference #18.14d302cc.1456420867.d615aa1d
Hi MaryMcG,
Please make sure you follow all of the Very Important Instructions listed on the linked page before clicking the download link.
Best,
Del
