1 Reply Latest reply on Nov 24, 2015 5:55 AM by Jeff_Coatsworth
    Change default text in Skin editor
    LykkeErik Level 1
      Hope someone can help. I need to change the default text in the Webhelp Skin editor under Search - area above the navigation pane (below marked in red):
      The problem is I need the font size to be size 11 to tally with the layout and since I cannot control the devision line, I hoped I could controll the wording in that particular area?
      In the generated Webhelp part of the text is cut off:
      Any idears?
        • 1. Re: Change default text in Skin editor
          Jeff_Coatsworth Adobe Community Professional & MVP
          I would check the LNG file (Projects > Settings – Language) you might be able to change the text in there (if never tried to change that part).
          You can also change the width of the left hand pane by doing this (old post):
          1. You can do this whole operation with the project open in RoboHelp. I would create a new custom skin first to try it on.
          2. If your project is in source control, check out the skin file first (example fred.skn).
          3. In Windows Explorer, find the .skn file - by default, it's stored in projectfolder\!SkinSubFolder!\skinfolder.
          4. Open the .skn file in any text editor. Notepad works fine.
          5. There are two lines that start with "frameset cols=" in the skin file. Default is <frameset cols="220,*"  etc.
          6. Change the 220 to the number of columns you want. Make sure you change it in both places.
          7. Save the skin file.
          8. Generate the project with the edited skin and display the project. (If you open it in IE and your settings suppress ActiveX content, you will need to allow active content before the TOC pane resizes
