4 Replies Latest reply on Nov 24, 2015 9:02 AM by dj_paige
    Lightroom 6 Upgrade did not delete Lightroom 4.4
    kendallp55937744
      I upgraded from lightroom 4.4 to 6 and the initial problem was the new version did not delete the older version. But a bigger problem is: I imported another directory/folder and this folder appears in the older version of lightroom but not in the newer version of lightroom 6. I have repeatedly imported the missing folder in Lightroom 6 but the folder will not appear in the library view but the photos are present when I view all photos in the catalog. Do I delete Lightroom 6 and return to Lightroom 4.4 as II have not found a solution?
        • 1. Re: Lightroom 6 Upgrade did not delete Lightroom 4.4
          dj_paige Level 9
          Installing Lightroom 6 does not delete older versions of your software.
          Please confirm that when you are doing the import, you are actually using Lightroom 6. Go to the menu item Help->About Adobe Photoshop Lightroom and report what number is there.
          I don't understand this, the photos appear but the folder does not? Can you show us a screen capture? What happens if you right-click on one of the photos and select Go To Folder in Library? Doesn't that make the proper folder selected on the left hand side under Folders?
          • 2. Re: Lightroom 6 Upgrade did not delete Lightroom 4.4
            khatwani Adobe Employee (Admin)
            Hi kendallp,
            Greetings!!!
            Yes that does not delete your previous version as its an upgrade.
            However if you want you can manually uninstall the previous version.
            And as you said next that when you import anything to new lightroom it goes to old lightroom.
            This is practically not possible as the import goes to catalog and it might be the name of the catalog is lightroom 4 that is open in Lightroom 6.
            Can you please check what is name of the catalog ?
            Regards
            Jitendra
            • 3. Re: Lightroom 6 Upgrade did not delete Lightroom 4.4
              kendallp55937744 Level 1
              When I select all photographs in the Library view then scroll to the last
              photographs, I find the imported photographs. As suggested I right click on
              one of the photos selecting "Go to Folder in Library" lightoom shows all of
              my imported photos under an incorrect folder name of 2015 instead of the
              folder name on my C drive of which I selected and imported from. In summary
              the photos  about 1000 in number are under an incorrect folder with the
              name of 2015 rather than the directory name of "Bonaire" on my C drive. Do
              I delete the 1000 photos in the "all photographs" catalog then re-import
              hoping that Lightroom places the photos under the correct name of Bonaire?
              • 4. Re: Lightroom 6 Upgrade did not delete Lightroom 4.4
                dj_paige Level 9
                Most likely, you have (accidentally?) imported the photos using the COPY option, and so a copy has been made where Lightroom is finding the photos.
                To fix the problem, in Lightroom, you need to right-click on that folder where Lightroom found the photos, and select Update Folder Location. Then when the next dialog box appears, point to the "Bonaire" folder on your C drive. It may (or may not) warn you that doing so will merge folder, allow this merge.
                Deleting the photos and then re-importing is never a good idea, and so do not do this.
