7 Replies Latest reply on Nov 29, 2015 9:44 PM by A.T. Romano
    Problem with starting program
    szymons16229646 Level 1
      hi people
      My program adobe premiere elements 14 does not want to start up after installing a new version. im using win10. any ideas?
        • 1. Re: Problem with starting program
          A.T. Romano Level 7
          szu,pms
          Premiere Elements 14 on Windows 10 (can we assume 64 bit?).
          How far do you get after the install is said to be successful?
          Do you get to the Welcome Screen? If you click on Video Editor in Welcome Screen, is the program hanging up on one particular loading item? If so, which one?
          Please give more details.
          Thank you.
          ATR
          • 2. Re: Problem with starting program
            Hi.
            Yes it is win 10 64bit.
            I have welcome screen but when I'm clicking on video editing is nothing
            happen.
            W dniu wtorek, 24 listopada 2015 A.T. Romano <forums_noreply@adobe.com>
            napisał(a):
            Problem with starting program created by A.T. Romano
            <https://forums.adobe.com/people/A.T.+Romano> in Premiere Elements - View
            the full discussion <https://forums.adobe.com/message/8212291#8212291>
            • 3. Re: Problem with starting program
              A.T. Romano Level 7
              szymons
              Thank you for the reply.
              If you do not see a loading screen after you hit Video Editor, then we cannot use that to find out a specific place where loading process may be hung up.
              So, let us
              1. Determine if the problem exists with and without the antivirus and firewalls disabled?
              2. Determine if you have QuickTime 7.7.6 installed on your computer along with Premiere elements 14, and if you are running the program as administrator (from a user account with administrative privileges. QuickTime 7.7.6 for Windows
              3. Go to
              Local Disk C
              Program Files
              Adobe
              Adobe Premiere Elements 14
              and, in the Adobe Premiere Elements 14 Folder, find the file specially named Adobe Premiere Elements.exe. Right click that file, select and apply Run As Administrator.
              Then double click the file to determine if it opens to the Premiere Elements 14 workspaces.
              4. Determine if your video card/graphics card is up to date according to the web site of the manufacturer of the card.
              5. What is a description of your computer operating system?
              Let us look at the above factors and then decide what next based on the details in your reply.
              Thank you.
              ATR
              • 4. Re: Problem with starting program
                saurabh___arora Level 1
                Can you please right click on Adobe Premiere Elements  exe and click on Run as Administrator ?
                -Saurabh
                • 5. Re: Problem with starting program
                  A.T. Romano Level 7
                  Saurabh
                  Your post 4 suggestion has already been made in my post 3
                  3. Go to
                  Local Disk C
                  Program Files
                  Adobe
                  ATR
                  • 6. Re: Problem with starting program
                    Hmm I have theory.
                    I open and close program 3 times by clicking red x in corner. Maybe program
                    go crazy because of that? Is better to close program by going setting and
                    clicking close program?
                    W dniu piątek, 27 listopada 2015 saurabh___arora <forums_noreply@adobe.com>
                    napisał(a):
                    Problem with starting program created by saurabh___arora
                    <https://forums.adobe.com/people/saurabh___arora> in Premiere Elements
                    - View the full discussion
                    <https://forums.adobe.com/message/8220586#8220586>
                    • 7. Re: Problem with starting program
                      A.T. Romano Level 7
                      szymons
                      An opened Premiere Elements (14 or other) should close
                      1. Clicking on the X at the top right of the work space
                      or
                      2. File Menu/Exit
                      When a program does not close, then there is a problem that needs to identified and corrected, sometimes by uninstall/reinstall.
                      But, the problem in this thread is that the Premiere Elements is not opening. There are a lot of causes for that and that is being explored in the discussion in progress. One of the reasons not mentioned yet is that Premiere Elements 14 process is opened already. That idea can be ruled in or out by checking the process's status in the Task Manager.
                      If you are clicking the X close three times to close your Premiere Elements projects, the project is likely closing the program already before you get to click 2 and 3.
                      If you are having problems with your Premiere Elements, please start a new thread and tell us the details of your situation. Then we can focus on it in detail and avoid confusion.
                      ATR
