Hi Guys
I have a SQL statement which caclulates the running balance
for a list of transactions in a transactions table. This SQL
statement is as follows:
SELECT transID, debit, credit,
(SELECT SUM(debit-credit)
FROM transactions as D1
WHERE D1.transID <= D0.transID) AS balance
FROM transactions AS D0
The only problem I'm having is that I have to display
transactions between a particular date range. I have for eg.
transID, transDate, debit, credit fields in my db.
However the problem I'm having is that when the transaction
records are pulled out for the specified date range the balances
are only calculated for those records. I need someway of having a
balance b/f (brought forward) so that the selected records use that
as a 'starting' balance and then calculate the running balance as
normal.
Any easy solutions?
Many, many thanks for your help in advance.
All the best
Wesley
