2 Replies Latest reply on Nov 25, 2015 5:46 PM by hillfilms
    Pro Import from Avid Mc Sequence flags Unsupported Media?
    hillfilms
      I can pro import an aaf file from Avid MC and if I choose to connect just to avid media, I can import without a problem.
      But if I choose to create QT reference files, I get an UNSUPPORTED MEDIA window which states that the version of Pro
      Import does not recognize the media (although I have the latest version of AE)
      Is there anyway I can create the QT reference files and then pro import the aaf?
      John
        • 1. Re: Pro Import from Avid Mc Sequence flags Unsupported Media?
          Dave LaRonde Level 6
          Mmmmmmmm.... I don't think so.  Assuming that you imported the QT Ref files into Avid and THEN exported an aaf for AE, I think there will always be trouble.
          Here's why:  A QT Ref file is simply a pointer to the actual media.  What are you making when you export an aaf from Avid?  You're making a collection of pointers to the original media files.  So in the case of QT Ref clips, the aaf would have pointers to pointers, which is giving AE fits.
          • 2. Re: Pro Import from Avid Mc Sequence flags Unsupported Media?
            hillfilms Level 1
            Hi Dave,
            Thanks for your help! Actually I'm working with mxf media within Avid and exporting an aaf of the mxf media. As I said, all works great - as it should - when I pro import into After Effects but only when I check Connect After Effects directly to Avid Media Files...if I check Create QT reference files to Avid Media Files instead...I get this unfortunate window:
            THANKS!
